rattlerMark Posted December 26, 2013 Share Posted December 26, 2013 my laptop that was supporting RailMaster Software recently failed and therefore I have purchased a new lap top (windows 8). I've been trying to re-activate RailMaster software (original version 1.21) now installed onto the new laptop. When prompted, I have entered my activation number supplied with the original software into the activation box (first inserting the CD into the drive) and on each occasion (4 times) it comes up with ‘software activation error connecting to gateway error 0’ or ‘unable to enter resource cannot connect 12029’. My previous laptop lost internet connection and therefore I have been unable to de-activate the software on that laptop. Therefore I am assuming this is why I cannot re-activate the RailMaster software now installed on my new laptop. the new laptop is connected to the Elite Unit with Firmware 3.1. I have not upgraded either the Elite or the RailMaster Software since installation in 2011 and had no previous problem until now. Just prior to my old computer failure I noticed that the Hornby RailMaster software had gone to ‘evaluation mode’ and I was unable to restore this to the full program (internet connection lost) and unable to use the many programs I had written. Can anyone advise me what I should do? I am aware that I should be able to continue using the software that I originally purchased if it can be re-activated onto the new laptop. thanks Link to comment Share on other sites More sharing options...
RDS Posted December 26, 2013 Share Posted December 26, 2013 @rattlerMark You need to email RailMaster support directly on support@rail-master.com. The software must be de-registered from your previous PC and the support team will do that from their end for you. They are supporting users over the Christmas break. (There is a very similar case for someone else show a few threads below this one called 'cannot de-register) Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted December 26, 2013 Share Posted December 26, 2013 To resolve this problem just download and install the latest RailMaster program from www.powerpos.com/rail-master/rm_setup.exe remembering to save it to a temporary folder first then rght-clicking on it and selecting "Run as administrator". Also ensure that RailMaster has been added as a full exception to both your antivirus and firewall software. To check the administrator status of the program (in case you already installed it without administrator status) right click on the icon you use to run the program, select "Properties", click on the Compatibility tab and ensure the box "Run as administrator" is checked. Link to comment Share on other sites More sharing options...
rattlerMark Posted December 27, 2013 Author Share Posted December 27, 2013 RDS said: @rattlerMark You need to email RailMaster support directly on support@rail-master.com. The software must be de-registered from your previous PC and the support team will do that from their end for you. They are supporting users over the Christmas break. (There is a very similar case for someone else show a few threads below this one called 'cannot de-register) Thanks for your help RDS I'll send an email Link to comment Share on other sites More sharing options...
RDS Posted December 27, 2013 Share Posted December 27, 2013 @rrattlerMark Hopefully you have sorted this by now but I noticed that HRMS had also responded to your thread by advising you to download the latest version from www.powerpos.com/rail-master/rm_setup.exe Maybe they have already sorted out your licence from their end. I have always had to add the latest version number into that web address so for example now it would be www.powerpos.com/rail-master/rm_setup155.exe. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 27, 2013 Share Posted December 27, 2013 RDS, this by no means the first time HRMS has said to use the straight setup file in lieu of the 155 version. And Mark, follow what they say, they're the ones who know. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 27, 2013 Share Posted December 27, 2013 And Mark, you should definitely upgrade your Elite firmware to v1.41. Link to comment Share on other sites More sharing options...
RDS Posted December 27, 2013 Share Posted December 27, 2013 @Fishmanoz Yes, I agree, HRMS are the ones to follow. I was merely pointing out that I had needed to add the version number at times previously but it seems now that leaving it off, loads the latest version. Link to comment Share on other sites More sharing options...
