dancemaster Posted August 10, 2011 Share Posted August 10, 2011 Hi FolksDoes anyone know if you can print out the track plan from Railmaster ?ThanksRegardsDM Link to comment Share on other sites More sharing options...
Brightstar Posted August 10, 2011 Share Posted August 10, 2011 I have not tried it with railmaster, but if you hold down the Ctrl key while pressing P, this will invoke the printing function in Windows. Link to comment Share on other sites More sharing options...
dancemaster Posted August 10, 2011 Author Share Posted August 10, 2011 Thanks Brightstar, Next time I have Railmaster running I will give it a go. Link to comment Share on other sites More sharing options...
ace10086 Posted August 10, 2011 Share Posted August 10, 2011 or try the 'print screen' key to copy the whole screen to the clipboard (or alt+print screen to copy the active window) where you can then paste into Paint etc.depending on your keyboard you may need to hold down the function key (FN) + insert for Print Screen. Link to comment Share on other sites More sharing options...
dancemaster Posted August 31, 2011 Author Share Posted August 31, 2011 Brightstar and ace 10086... thank you both for your info.Sorry it's been so long to reply...I have found a freebie screen grabber on the net, it allows me to select a portion of the screen and save it in .jpg format.I set Railmaster to 100% and grabbed all the sections of just the layout plan in Railmaster and pieced them all together in Elements, then I was able to do a printout and it worked fine.Cheers Guys ! Link to comment Share on other sites More sharing options...
