Pennmill Posted January 15, 2014 Share Posted January 15, 2014 Bought a new class 153 approx 8 months ago, it now does not go, however the directional lighting still works, have tried putting power direct to the wheels, but still not working, any advice? Link to comment Share on other sites More sharing options...
RDS Posted January 15, 2014 Share Posted January 15, 2014 @Pennmill I would return it to the seller if that is possible because it should still be under warranty. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted January 16, 2014 Share Posted January 16, 2014 Taking a stab n the dark, because there's not much information there, either the motor has jammed, for some reason, or the brushes are worn out! Does the motor buzz at all, when you expect the train to move? If it is buzzing, there is either debris in the drive, or something is out of line. As RDS said, it is still under guarantee take it back. Link to comment Share on other sites More sharing options...
Pennmill Posted January 20, 2014 Author Share Posted January 20, 2014 2e0dtoeric said: Taking a stab n the dark, because there's not much information there, either the motor has jammed, for some reason, or the brushes are worn out! Does the motor buzz at all, when you expect the train to move? If it is buzzing, there is either debris in the drive, or something is out of line. As RDS said, it is still under guarantee take it back. Link to comment Share on other sites More sharing options...
Pennmill Posted January 20, 2014 Author Share Posted January 20, 2014 No sounds from motor and nothing obvious around motor. Looks like a trip to model shop . Thanks anyway. Link to comment Share on other sites More sharing options...
