voyager1 Posted January 23, 2014 Share Posted January 23, 2014 Hi, I am having difficulty in creating a route to change a crossover i.e. 2 points. have tried wiring 2 points into 1 terminal and this does work on another set a further up the track... However, this is being a real pig to achieve on this set. Both change independently i.e. on their own with a port each but when wired together - one really struggles... I have tried to set up a Route to solve this but at the moment to no avail... It does not respond at all. Is there any instructions on how to do this easily as the manual kind of skips over this. Sincere thanks. Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 23, 2014 Share Posted January 23, 2014 What kind of points / point motors are you using? Are you using R8247 accessory decoders? Have you definitely wired them in parallel, rather than in series? Ray Link to comment Share on other sites More sharing options...
96RAF Posted January 24, 2014 Share Posted January 24, 2014 St1ngr4y said: What kind of points / point motors are you using? Are you using R8247 accessory decoders? Have you definitely wired them in parallel, rather than in series? Ray I know you pick the point and select the route for it to fire on, but can you repeat the points fire command say at the beginning of the route then later on down the timeline. Link to comment Share on other sites More sharing options...
St1ngr4y Posted January 24, 2014 Share Posted January 24, 2014 RAF96 said: I know you pick the point and select the route for it to fire on, but can you repeat the points fire command say at the beginning of the route then later on down the timeline. I think you are mixing up routes and programs. You can't repeat a point firing with a route, but you can with a program. Ray Link to comment Share on other sites More sharing options...
Graskie Posted January 24, 2014 Share Posted January 24, 2014 Or perhaps the points or one of the points can't move as freely as it or they should for some reason. Are they totally flat but not pinned into or stuck too tightly the baseboard? Do the blades move easily with manual operation? Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 24, 2014 Share Posted January 24, 2014 Agree with Graskie that you should make sure your points are operating freely first. Then if still a problem, would be handy to know just what you are using as Rsy asked. Finally, you might like to lengthen the pulse on the decoder port from its 100mSec default to not more then 500mSec. Tell us how you go. Link to comment Share on other sites More sharing options...
Creweite Posted February 10, 2014 Share Posted February 10, 2014 voyager1 said: Hi, I am having difficulty in creating a route to change a crossover i.e. 2 points. have tried wiring 2 points into 1 terminal and this does work on another set a further up the track... However, this is being a real pig to achieve on this set. Both change independently i.e. on their own with a port each but when wired together - one really struggles... I have tried to set up a Route to solve this but at the moment to no avail... It does not respond at all. Is there any instructions on how to do this easily as the manual kind of skips over this. Sincere thanks. Link to comment Share on other sites More sharing options...
Creweite Posted February 10, 2014 Share Posted February 10, 2014 I had the same problem solved it by using a 19 Volt 3.6amp computer power supply unit as aux power supply instead of the aux supply on my elite controller works fine now when points are fired from railmaster track plan, hope this helps. Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 10, 2014 Share Posted February 10, 2014 Hi Crew, let us know what it is that you are powering with the auxiliary supply please? I assume one of the types of accessory decoder that allows for such a separate supply? Interesting if that is really the case. Says to me that the decoder wasn't well designed in the first place as the thing that should be firing the points is the internal CDU, given there is one. There would be little time for the supply to recharge the CDU in any fashion, given it was adequate in the first place. Link to comment Share on other sites More sharing options...
