Hadders46 Posted January 25, 2014 Share Posted January 25, 2014 I am trying to install a Digirail DR4018 decoder, but there is no definition for this item. How can I set the 8 addresses ? Link to comment Share on other sites More sharing options...
RDS Posted January 25, 2014 Share Posted January 25, 2014 The manufactures website contain a full user manual. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 26, 2014 Share Posted January 26, 2014 Dead simple according to the manual. In fact no accessory decoder is simpler than this one. Note that while your starting address can be anything, put it in learn mode, throw a point and the whole thing is done. I suggest to keep it simple if you may use different brands of decoder on you layout, you use a starting address that is a multiple of 8 plus one. Then it will work more simply with anything like the Hornby 8247 that uses group addresses. You won't then have point or signal numbers you can't use. Link to comment Share on other sites More sharing options...
Rewob Posted February 19, 2014 Share Posted February 19, 2014 Dear All I recently bought a DR4018 to try to drive eight 2-aspect colour light signals. Although, as Fishmanoz said, addressing the DR4018 is very straightforward (just press the programme button on the decoder and operate the point/signal corresponding to the first address required), the problem I have is that the DR4018 is preset with CV47 = 0 (to drive eight points) so the outputs are momentary (hence the signal LEDs light up and then go off almost immediately !). What I want to do is set CV47=2 (for eight 2-aspect signals with fade effect) or set CV47=1 (16 permanent on/off switches - which would actually allow me to operate up to 16 signals via a series of cheap-and-cheerful Tandy SPDT relays !) but I can't write to this CV as the DR4018, as has been pointed out, isn't on the Railmaster list of 'approved' decoders. I have tried writing to the DR4018 using all of the read/write configurations listed in Railmaster without success. I thought the best bet may be a Lenz definition since Lenz appears in both Railamster and the DR4108 documentation. I have been in touch with Digirails who make the DR4018 and sent them details of Railmaster/eLink which they requested. I am waiting for their reply. Fiona at DCCsupplies, who supplied the DR4018, is trying to test the DR4018 on a Railmaster/eLink set-up just in case I have a duff DR4018. I'm going to phone her on 26/2/14 when she's back from hol to see if she had any success. She did say that some time ago she had submitted the DR4018 to Ken in Hornby's Technical Department for evaluation but I don't have anything to confirm that. I have been in touch with Mark at Hornby Customer Care and he has passed details of teh DR4018 onto Ken in Hornby Technical. The feedback from Mark today (19/2/14) was that it may be along process and there's no guarantee that the DR4018 will ever appear on the Railmaster approved list (unless lots of people ring up or e-mail requesting it !!). If DCCsupplies/Hornby/Digirails can't solve the problem it seems I have the following options - i) Return the decoder to DCCsupplies (Fiona did said they would do a refund) and buy another type or decoder (not sure there's anything which looks as good value-for-money as the DR4018) ii) Ask DCCsupplies if they would think about setting up a basic programming service (just for CV47 perhaps ?) iii) Try to sweet-talk Digirails into sending a decoder with CV47 already set to 1 iv) Install some latching relays thereby converting the momentary outputs for points into latched outputs for signals v) Try to find someone who has a programmer which can set CV47=1 (does anyone know a helpful person or club who could do this for me ??) ... unless anyone has any other suggestions ? Regards Link to comment Share on other sites More sharing options...
Rewob Posted February 19, 2014 Share Posted February 19, 2014 PS It's a shame Railmaster/elink can't somehow have a 'generic' accessory decoder for very experienced DCCers where all decoder CVs are both readable and writable (like for locos ?) without having to select an accessory decoder from an approved list. Is this possible Ken (Hornby Technical Dept) ?? Regards Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 20, 2014 Share Posted February 20, 2014 Hi Rewob, HCC is not the best place to go for this sort of question. They don't have the detail and have to track down somebody who does. Suggest instead you email RM Support from within the Help window of RM. They should know the answer for you. Hopefully, you can set it to something in the list of decoders that will allow you to change the necessary CVs, or they may even add something for you. Link to comment Share on other sites More sharing options...
papajulietdelta Posted February 20, 2014 Share Posted February 20, 2014 I invested in a Sprog (about £50) plus JMRI software (free) to program all makes of loco and accessory decoders. Far easier and more reliable than an Elite or Railmaster. Cheers Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 20, 2014 Share Posted February 20, 2014 We are on the Hornby forums here so we shouldn't be discussing systems that compete with Hornby products. But yes of course you can use JMRI, or Java Model Railway Interface, instead of RM but only if you are more technically minded than needed for RM. RM is intended to keep it simple for the non-technical user. Anyone who thinks RM is highly technical will really be at sea with JMRI. And I think that HRMS is doing a great job with RM, listening to users and making the product more capable and friendly all the time (no, I'm not connected to Hornby in any way, nor do I have shares). That said, the very nature of the DCC specification means that some level of understanding and ability is needed to operate it. Even if all you ever do is program decoders to the desired address. Link to comment Share on other sites More sharing options...
papajulietdelta Posted February 21, 2014 Share Posted February 21, 2014 My point Fish, is that there is another relatively cheap system for programming decoders that is more comprehensive. I find Decoder Pro very easy to use. It solves a lot of the problems members have reading and writing to loco and accessory CVs. I am a great fan of Railmaster and the Elite for operating my layout. I have now successfully converted from ZTC. Although, I do miss the brake, which stopped me hitting the buffers! Cheers Link to comment Share on other sites More sharing options...
Rewob Posted February 21, 2014 Share Posted February 21, 2014 Dear Fishmanoz / PJD Below is the e-mail I've just received from Digirails - the manufacturer of the DR4018 decoder. I've sent it to Mark at Hornby asking if he could forward it to Ken in Hornby's Tech Dept for his consideration just in case it's a matter of making a minor tweak to Railmaster. Agree we shouldn't be promoting non-Hornby products on this site BUT if this allows a generally available decoder to be programmed to work with Railmaster then this might be excusable ? I'll try contacting RM Support from within Railmaster as suggested but I can't help feeling that the question may just land on Ken's desk via another route ! Thanks for your interest and support guys. I'll keep you posted but please let me have any other ideas that may come to mind. Kind regards Rewob --------------------------------------------------------------------------------------------------------------------- From: support@digikeijs.com To: Rewob Subject: Re: To Roy Keij - DR4018 & Hornby Railmaster/eLink Dear Mr. Rewob If the railmaster supports "CV programming" of POM programming it must be possible to put value 1 inside CV47. It is also possible to order the DR4018 with pre programmed preset on our website. Please put your programming demands in the notice field of your order. Kind regards, Roy Keij DIGIKEIJS Link to comment Share on other sites More sharing options...
Fishmanoz Posted February 22, 2014 Share Posted February 22, 2014 Your email to RM Support is unlikely to land on Ken's desk as they are not actually Hornby but a separate company. Much more likely that Ken has to contact HRMS to get your answer. Link to comment Share on other sites More sharing options...
alan_french Posted September 9, 2014 Share Posted September 9, 2014 ok ready thatBut will it work on hornby e-Link ????Just what i Want if it will work with my e-Link Thanks. Alan Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 9, 2014 Share Posted September 9, 2014 Short answer is yes. It is of the type where you connect to the track, put it in program or learn mode with the switch on it, use RM to throw the point you want it to control, switch it back to run mode and it's done. Link to comment Share on other sites More sharing options...
dale_andrew Posted September 15, 2014 Share Posted September 15, 2014 Why does the Hornby R8216 Point decoder not work with Railmaster? Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 15, 2014 Share Posted September 15, 2014 Dale, never a good idea to hide your completely new topic at the bottom of a thread on something else, better to start a new one. Or better still, if you'd done a forum search on 8216 you'd have found the previous threads on how to do this. And I'm not saying this to be critical, just to help you to help us get you an answer. So your short answer is - of course you can program it but it is a bit tricky, so make sure you follow the instructions about setting it up correctly in the first place. It is covered on p72 of the manual and then there is guidance when you select it from the list of decoders to program in RM. Link to comment Share on other sites More sharing options...
