Aj1 Posted January 26, 2014 Share Posted January 26, 2014 Also what is does it mean/do? Link to comment Share on other sites More sharing options...
96RAF Posted January 26, 2014 Share Posted January 26, 2014 It means RM can read your loco decoder configuration variables (as far as that is possible with the particular decoder - some decoders can have more CVs read than others) and allow you to change them to suit your requirements - e.g. acceleration/deceleration rates and many other parameters. To be able to do this you need to set up a piece of track isolated from your main track and connected to the eLink/Elite PROG terminals. Link to comment Share on other sites More sharing options...
Aj1 Posted January 26, 2014 Author Share Posted January 26, 2014 Thank you - what to do after you have put it on the isolated track? Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted January 26, 2014 Share Posted January 26, 2014 You would be advised to invest a little time in reading the RailMaster PDF guide installed on your Windows desktop thoroughly as you are asking questions that are readily answered in the guide. The forum is really intended for questions where users have exhausted their knowledge and the contents of the documentation. Your Western Master eLink train set comes with the loco and track plan already set up (assuming you selected "Western Master" from the installation options when first running RailMaster). This means the loco is set to DCC ID 3 and the software knows this and has already set your loco to DCC ID 3 and placed it on the locos list. You need to ensure you have followed the instructions carefully and if necessary also consult the Driver Installation PDF guide also installed on your Windows desktop as it could be a simple matter of looking at the connection from the TRACK output of your eLink controller to your layout. The above also covers your other two postings on this forum under "Train not moving" and "Why won't RM pick up my train automatically?". Link to comment Share on other sites More sharing options...
Aj1 Posted January 26, 2014 Author Share Posted January 26, 2014 Hi, my train set is not working. Everything seems fine apart from when I press go on the loco, nothing happens. I am getting worried and wondered if there was any additional information to the answers in the PDF that I could find here. Link to comment Share on other sites More sharing options...
Aj1 Posted January 26, 2014 Author Share Posted January 26, 2014 I have read through it many times, and have tried working my train on 3 different computers. Each time has not worked Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 26, 2014 Share Posted January 26, 2014 AJ, you aren't giving us much to go on to help you, apart from following the PDF manual as HRMS suggests. So to help us help you,tell us what you have done to try to set things up, starting with opening the box and working from there. Then we can see where your troubles start. Link to comment Share on other sites More sharing options...
