andys steam dayz Posted March 4, 2014 Share Posted March 4, 2014 Hi I wonder if anyone can help I am trying to install railmaster on my lap top I have got as far as software activation by internet filled all my details in then you have to tick the green box to activate keep getting a message unable to enter resource-cannot connect 12029 when loading I run as administrator and internet connection is on? Thanks in advance for any advice Regards Link to comment Share on other sites More sharing options...
cliveg Posted March 4, 2014 Share Posted March 4, 2014 Andy, Have you checked firewall and antivirus settings as they may be blocking the registration process? Link to comment Share on other sites More sharing options...
andys steam dayz Posted March 4, 2014 Author Share Posted March 4, 2014 Hi cliveg Thanks for your response phoned hornby and they said the same as you so will check my firewall and anti virus settings.Thank you once again Regards Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 4, 2014 Share Posted March 4, 2014 Assuming you have allowed RM to update to the latest v1.55, there will be a PDF guide on your desktop to assist you not being blocked this way. Link to comment Share on other sites More sharing options...
andys steam dayz Posted March 4, 2014 Author Share Posted March 4, 2014 Hi Fishmanoz I was trying to load my original disc I purchased a couple of years ago when hornby contacted me this morning they e-mailed me a PDF guide. Regards Link to comment Share on other sites More sharing options...
N18EDG Posted April 12, 2014 Share Posted April 12, 2014 Hi All, Sorry, noticed this thread about activation not working etc. I am new to Hornby / Railmaster and am having exactly this issue when trying to activate. I have checked all firewall settings, internet settings and still no luck. Any suggestions would be gratefully received. Many thanks. Link to comment Share on other sites More sharing options...
gilbo2 Posted April 12, 2014 Share Posted April 12, 2014 N18EDG said: Hi All, Sorry, noticed this thread about activation not working etc. I am new to Hornby / Railmaster and am having exactly this issue when trying to activate. I have checked all firewall settings, internet settings and still no luck. Any suggestions would be gratefully received. Many thanks. Might be worth trying to download RailMaster from the Hornby website, link below; http://www.powerpos.com/rail-master/rm_setup.exe Then right click the downloaded file and run as administrator. Link to comment Share on other sites More sharing options...
gilbo2 Posted April 12, 2014 Share Posted April 12, 2014 dgilbert2 said: Might be worth trying to download RailMaster from the Hornby website, link below; http://www.powerpos.com/rail-master/rm_setup.exe Then right click the downloaded file and run as administrator. Sorry, then make sure you follow the instructions in the pdf file to add railmaster to your security software. Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 12, 2014 Share Posted April 12, 2014 The important thing above is installation as administrator. If not done, you don't have to reinstall to fix, just right click on the RM desktop icon or tile, select Properties then the Compatibility tab, and make sure the run as administrator box is ticked. That fixes it. In fact, once installed, you should never need to reinstall, only update. If you haven't allowed RM to update to latest, you should restart it and it should automatically ask you if you want to update. Says yes and allow it to do so despite the warning that comes up about administrator, that should be Ok now. Once running the latest as administrator, you can check about your virus protection not blocking from the PDF guide that has been installed as part of update. Just one other thing if you are using W8.1, some have reported that you must run it in W7 compatibility mode. So if still having problems, you may need to go back to Properties, Compatibility and set W7 as the mode here. Hope that helps, let us know. Link to comment Share on other sites More sharing options...
gilbo2 Posted April 13, 2014 Share Posted April 13, 2014 Personally, I've been running on windows 8.1 for some months now and actually find it best to keep away from any compatability modes. Maybe it depends on the actual windows configuration. Link to comment Share on other sites More sharing options...
