Lowty1 Posted March 12, 2014 Share Posted March 12, 2014 Last night I set up an address on J64 loco for the very first time and set it as number 63, that being the last 2 numbers of the loco. I noticed that each programming button also has a letter on it. I would like to know can I set an address such as J64 to identify a particular loco? If so how can it be done? Thank you. Link to comment Share on other sites More sharing options...
RDS Posted March 12, 2014 Share Posted March 12, 2014 @Lowty1 You cannot use letters for the Loco DCC ID. You can name the Loco whatever you like if you have an Elite controller or RailMaster but even then the DCC ID must just be numbers. Link to comment Share on other sites More sharing options...
Flashbang Posted March 12, 2014 Share Posted March 12, 2014 Hi You cannot send Alpha/numeric data to a decoder as its address, the decoders address has to be a numerical value only. The Elite offers the ability to recall locos from a list and here you should be able to store a Alpha/numerical loco details. Page 44 of the Elite manual refers. Link to comment Share on other sites More sharing options...
Lowty1 Posted March 12, 2014 Author Share Posted March 12, 2014 Flashbang said: Hi You cannot send Alpha/numeric data to a decoder as its address, the decoders address has to be a numerical value only. The Elite offers the ability to recall locos from a list and here you should be able to store a Alpha/numerical loco details. Page 44 of the Elite manual refers. Link to comment Share on other sites More sharing options...
Lowty1 Posted March 12, 2014 Author Share Posted March 12, 2014 Thank you both. Link to comment Share on other sites More sharing options...
Graskie Posted March 12, 2014 Share Posted March 12, 2014 If you have an Elite or are using RailMaster with an eLink, you can set an ID as four digits instead of just two, which can help identify a loco by sight. For instance, Western Region locos only had four numbers, so you can can use them all. For other 5 digit BR numbers I always use the 1st, 3rd, 4th and 5th ones. The first number indicates other regions, for a start, and not using the 2nd number makes it less likely to get duplication with other loco numbers. This is not, of course, so necessary with the eLink combination, as the RM program can easily identify locos for you. If you are using just a Select, however, you can only program 2 number IDs. Link to comment Share on other sites More sharing options...
Lowty1 Posted March 13, 2014 Author Share Posted March 13, 2014 Graskie said: If you have an Elite or are using RailMaster with an eLink, you can set an ID as four digits instead of just two, which can help identify a loco by sight. For instance, Western Region locos only had four numbers, so you can can use them all. For other 5 digit BR numbers I always use the 1st, 3rd, 4th and 5th ones. The first number indicates other regions, for a start, and not using the 2nd number makes it less likely to get duplication with other loco numbers. This is not, of course, so necessary with the eLink combination, as the RM program can easily identify locos for you. If you are using just a Select, however, you can only program 2 number IDs. Link to comment Share on other sites More sharing options...
Lowty1 Posted March 13, 2014 Author Share Posted March 13, 2014 Thanks Graskie. This forum is going to be really useful to me. Link to comment Share on other sites More sharing options...
