m0eoujohn Posted May 12, 2014 Share Posted May 12, 2014 hi everyone I have rail master and elink and a dcc converted turntable how do I get this to work on this system do have to return the turntable back to standard and then use a point controller help john Link to comment Share on other sites More sharing options...
RDS Posted May 12, 2014 Share Posted May 12, 2014 Hi John I have a Hornby Turntable, Model R070 and use it on a DCC system, via RailMaster and an Elite controller. I have allocated id 070 to it and it works fine, just by calling it up as if it was a loco. Link to comment Share on other sites More sharing options...
St1ngr4y Posted May 12, 2014 Share Posted May 12, 2014 Hello John, No need to convert back to standard. The turntable has a motor in it so it is more like a loco than a point. If it has been converted to dcc then it will need an address like any other loco on your system. There is an icon available in the layout designer which you can place on your layout diagram. As with points and signals, you can right-click on the icon to configure it. There are entries in the railmaster.ini configuration file which need to be considered. The PDF guide gives you information about these. I have a turntable in my layout, and in addition to having the icon in my layout diagram, I also have it defined (with the same address) as if it were a loco. There is a reason for this. When you are operating the turntable using RM, you have to click on the left half of the icon to make it turn anticlockwise, and on the right half to make it turn clockwise. One click makes the motor run long enough to turn the table to the next road. How long the motor runs and how fast are the parameters defined in the railmaster.ini file. However, over a period of time, the table can get out of sync, so that after a turn, it stops midway between two roads. This is when I use the 'loco' definition for the turntable, because using this the turntable runs for as long as you want it to. I have the cruise speed in this definition set to the same value as the turntable speed definition in the ini file. Hope this helps. Ray Link to comment Share on other sites More sharing options...
St1ngr4y Posted May 12, 2014 Share Posted May 12, 2014 Hi RDS, You posted while I was typing - sorry about that. Ray Link to comment Share on other sites More sharing options...
RDS Posted May 12, 2014 Share Posted May 12, 2014 Hi Ray No problem at all. I think we said the same sort of thing (not surprising though because you helped me a lot with my set-up at the time) but with a lot more detail from you in your latest response. Link to comment Share on other sites More sharing options...
m0eoujohn Posted May 12, 2014 Author Share Posted May 12, 2014 St1ngr4y said: Hello John, No need to convert back to standard. The turntable has a motor in it so it is more like a loco than a point. If it has been converted to dcc then it will need an address like any other loco on your system. There is an icon available in the layout designer which you can place on your layout diagram. As with points and signals, you can right-click on the icon to configure it. There are entries in the railmaster.ini configuration file which need to be considered. The PDF guide gives you information about these. I have a turntable in my layout, and in addition to having the icon in my layout diagram, I also have it defined (with the same address) as if it were a loco. There is a reason for this. When you are operating the turntable using RM, you have to click on the left half of the icon to make it turn anticlockwise, and on the right half to make it turn clockwise. One click makes the motor run long enough to turn the table to the next road. How long the motor runs and how fast are the parameters defined in the railmaster.ini file. However, over a period of time, the table can get out of sync, so that after a turn, it stops midway between two roads. This is when I use the 'loco' definition for the turntable, because using this the turntable runs for as long as you want it to. I have the cruise speed in this definition set to the same value as the turntable speed definition in the ini file. Hope this helps. Ray Link to comment Share on other sites More sharing options...
m0eoujohn Posted May 12, 2014 Author Share Posted May 12, 2014 thanks to all that have replied yes it works with the elite but how do we program the turn table as it is not a point but a loco decoder so how is it numbered to make railmaster identyfi it and work from the rm screen Link to comment Share on other sites More sharing options...
Graskie Posted May 12, 2014 Share Posted May 12, 2014 Presumably you just program it as if it were a loco. Link to comment Share on other sites More sharing options...
St1ngr4y Posted May 12, 2014 Share Posted May 12, 2014 Post a new reply... Link to comment Share on other sites More sharing options...
St1ngr4y Posted May 12, 2014 Share Posted May 12, 2014 Hi John, If you have put the turntable onto your layout diagram using the correct icon, and configured that with the address it has been given, then when you are in the program editor, in the column headed 'Resource' you will find a category designated 'Other'. Click on that then in the column headed 'resource name' you should find the turntable. In the instruction column, you will find all of the available actions you can perform i.e. Clockwise 1, Clockwise 2 etc. Ray Link to comment Share on other sites More sharing options...
St1ngr4y Posted May 12, 2014 Share Posted May 12, 2014 m0eoujohn said: thanks to all that have replied yes it works with the elite but how do we program the turn table as it is not a point but a loco decoder so how is it numbered to make railmaster identyfi it and work from the rm screen Again, if it is on your layout diagram, then you can click the left half of the icon to make it go anti-clockwise, or right half for clockwise. You can click as many times as roads you want it to rotate. Each time you click, the number of roads is displayed by the icon on the diagram. This number disappears after the rotation has completed. Ray Link to comment Share on other sites More sharing options...
m0eoujohn Posted May 12, 2014 Author Share Posted May 12, 2014 St1ngr4y said: Hi John, If you have put the turntable onto your layout diagram using the correct icon, and configured that with the address it has been given, then when you are in the program editor, in the column headed 'Resource' you will find a category designated 'Other'. Click on that then in the column headed 'resource name' you should find the turntable. In the instruction column, you will find all of the available actions you can perform i.e. Clockwise 1, Clockwise 2 etc. Ray Link to comment Share on other sites More sharing options...
m0eoujohn Posted May 12, 2014 Author Share Posted May 12, 2014 thanks ray will try that looks like I missed something john Link to comment Share on other sites More sharing options...
m0eoujohn Posted May 27, 2014 Author Share Posted May 27, 2014 thank you all for your help it is now working Link to comment Share on other sites More sharing options...
