backontrack Posted June 13, 2014 Share Posted June 13, 2014 I have just had my select controller firmware updated by Hornby to1.4. On trying the updated product I was unable to get the controller to alter direction.(the right hand indicator lit up and the loco went forward but when operated the left hand indicator would not light up) I reset the unit and tried four other locos which all worked fine in both directions. I then tried the first loco again and could not get it to work in any direction. I swapped a decoder from one of my other locos into the first loco and it works fine in both directions. Could a fault with the controller have damaged the decoder?. The unit has been returned to Hornby for investigation. Also button number 7 on the controller is not working. Link to comment Share on other sites More sharing options...
Fishmanoz Posted June 13, 2014 Share Posted June 13, 2014 First, I assume your firmware update is 1.41, not 1.4? If 1.4, it needs to be updated to 1.41 As 1.4 has bugs. And I would think it most unlikely the Select has caused any decoder damage, it will just be a decoder fault. Link to comment Share on other sites More sharing options...
backontrack Posted June 14, 2014 Author Share Posted June 14, 2014 Thanks for the info regards the decoder, and yes it was the 1.41 upgrade. Link to comment Share on other sites More sharing options...
ff2nd Posted June 19, 2014 Share Posted June 19, 2014 Are you sure about that Fishman? I think the Elite update is 1.41, but the Select screen doesn't have enough characters to show that. Link to comment Share on other sites More sharing options...
96RAF Posted June 19, 2014 Share Posted June 19, 2014 The select revison state is indicated by a code that appears on the startup screen. See here by Wiggy25 https://www.hornby.com/forum/select-firmware/But if HCC updated it for you it should be at the latest state regardless. Link to comment Share on other sites More sharing options...
Fishmanoz Posted June 19, 2014 Share Posted June 19, 2014 You are of course correct ff. I'm talking through my hat again. Link to comment Share on other sites More sharing options...
