graham_scholes Posted July 21, 2014 Share Posted July 21, 2014 still having trouble with 08 shunter out of mixed goods set going the wrong way on controls..read about it in forum but still having problems.is there an easy web site for helpback into trains after 25yrs gap.bought digital mixed goods set to start up again Link to comment Share on other sites More sharing options...
Flashbang Posted July 21, 2014 Share Posted July 21, 2014 HiThere are three ways of reversing the normal direction of travel of a DCC loco.1) Hornby Select & Elite users can correct this directly on the programming track via the console settings. This may well also apply to the eLink too? Refer to the units manual to see how to do this... Select page 12, Elite page 29.2) Swap around the two wires (Orange and Grey) on the locos motor.3) If your DCC system allows it (Hornby Elite and possibly the eLink? and many other makes of DCC systems) alter the value set into CV29 by adding or subtracting 1 to whatever is set currently. Example.... Read existing CV29 value - If it reads as an even number add 1, if odd number deduct 1. i.e. read value of 6 make CV29 value 7 or if read 7 make it 6 or for higher values e.g. 35 make it 34 or read 34 make it 35. Link to comment Share on other sites More sharing options...
graham_scholes Posted July 21, 2014 Author Share Posted July 21, 2014 thank you for your help Link to comment Share on other sites More sharing options...
Graskie Posted July 21, 2014 Share Posted July 21, 2014 I don't know whether anyone has mentioned this or you already knew, but this shunting diesel ran forwards grill first and backwards cab first. It is easy to think it should be the other way round. Link to comment Share on other sites More sharing options...
walkingthedog Posted July 21, 2014 Share Posted July 21, 2014 Isn't he saying that it goes in the opposite direction to his other locos. Doesn't matter if it's grill or cab first. Link to comment Share on other sites More sharing options...
Graskie Posted July 21, 2014 Share Posted July 21, 2014 Well, if you run two DCC locos on the same DCC track, facing in opposite directions, they will move apart from each other or into each other if both are set forward or backwards respectively . There's no clockwise or counter clockwise control with DCC, as there is with analogue, WTD. So if the wrong front end is assumed, it could cause such confusion. Link to comment Share on other sites More sharing options...
walkingthedog Posted July 21, 2014 Share Posted July 21, 2014 Of course I forgot that Graskie. There is a front and back with DCC. So if you have two locos on the track facing in different directions, tender to tender for instance, and you want them to move apart you tell both of them to go forward and they will move apart. Forward will alway be pulling the tender. Link to comment Share on other sites More sharing options...
Graskie Posted July 21, 2014 Share Posted July 21, 2014 Nice to know I've offered some decent advice at last, WTD. Link to comment Share on other sites More sharing options...
walkingthedog Posted July 21, 2014 Share Posted July 21, 2014 Yes you'd better put that on your calendar. Link to comment Share on other sites More sharing options...
graham_scholes Posted July 26, 2014 Author Share Posted July 26, 2014 thank you for all the help. Link to comment Share on other sites More sharing options...
Graskie Posted July 26, 2014 Share Posted July 26, 2014 Have you resolved things then, Graham? If so, what was the problem and how did you resolve it? Link to comment Share on other sites More sharing options...
