gilbo2 Posted August 10, 2014 Share Posted August 10, 2014 98% of my locos are fitted with the R8249 decoder and controlled with Railmaster / eLink. Most suffer from the same "issue" where when incrementing in 1mph steps, at every x0mpg (e.g. 10,20,30,40mph etc.) there is a rise in speed that drops away at x0mpg +1 (e.g. 11,21,31,41mph etc.). So is this Railmaster that's causing these speed “spikes” or the speed table in R8249? Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 10, 2014 Share Posted August 10, 2014 Not the first time this has been reported dg. Suggest you email RM Support as they have said they hadn't experienced this before and your having it happen with such consistency may give them more to think about. Link to comment Share on other sites More sharing options...
gilbo2 Posted August 12, 2014 Author Share Posted August 12, 2014 Have done a few tests tonight and the problem does look to be in some RailMaster profiles. Some profiles (using the same "test" ringfield based loco) are more pronounced than others and some are good. Without going through all the 60 profiles I use, I have tried about 10. In summary, the default "no name" profile works well and so did an X04 based profile, eg Albert Hall R759. R3153, R352 profiles not so good.HOWEVER, its probably best left alone as I guess that changing the profiles in a furture update will mess up all of my programs, so best not to touch and live with it!!Have dropped them an email. Link to comment Share on other sites More sharing options...
Michael_A Posted August 14, 2014 Share Posted August 14, 2014 It's odd that these issues aren't discovered in testing. Maybe Hornby do the old probablity of it affecting users versus costs to resolve calculation. Or maybe their test protocols dont pick these things up.I was very dissapointed in the discrepancy in scae speed, but it seems nobody else either cares or has stumbled across theissue. Thats what you get buyingnew toys that show scal speed, though I resorted to a stop watch in the end as I was beginning to mistrust my speed wagon. I gess the very fact thatHornby says have built in a number of alignement steps in the new release indicates they were awrae it could be improved.Hopefully after your feedback dgilbert2 they willbe working on a fix for that issue too... Link to comment Share on other sites More sharing options...
gilbo2 Posted August 14, 2014 Author Share Posted August 14, 2014 Hornby are doing tests on this at the moment but so far unable to replicate. Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 14, 2014 Share Posted August 14, 2014 Just clarify, it is HRMS you are talking to about this isn't it, not HCC? Link to comment Share on other sites More sharing options...
gilbo2 Posted August 15, 2014 Author Share Posted August 15, 2014 I assume so, all triggered from an in app help request. Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 15, 2014 Share Posted August 15, 2014 They're the right ones. Not actually Hornby but their RM contractor. Link to comment Share on other sites More sharing options...
gilbo2 Posted August 15, 2014 Author Share Posted August 15, 2014 I assume you mean Powerpos? Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 15, 2014 Share Posted August 15, 2014 Yes, or whoever it is behind the Powerpos site. Link to comment Share on other sites More sharing options...
gilbo2 Posted August 31, 2014 Author Share Posted August 31, 2014 More information;I have recently setup two more locos;R3216 Class 67 Diamond Jubilee with Loksound 4 decoderR2171 Merchant Class with R8249 decoderBoth these exhibit the same speed spike at 10,20,30,40mph etc Link to comment Share on other sites More sharing options...
