Jailor Posted September 9, 2014 Share Posted September 9, 2014 After waiting for the illusive Hornby decoder to arrive I eventually bought the ADS8 decoder for my points, I use e-link and RM. My question is this, I have used 7 of the 8 ports to control Hornby surface point motors. Would I be able to wire a semaphore signal into the empty port and if so do I have to change any settings to get it to fire? If I do need to alter any settings what are they and how do I do so?Thanks in advance of any helpfull comments. Ron. Link to comment Share on other sites More sharing options...
da4472vid Posted September 9, 2014 Share Posted September 9, 2014 I woudn't think so BUT I run normal DC Link to comment Share on other sites More sharing options...
Flashbang Posted September 9, 2014 Share Posted September 9, 2014 HiThe AD-S8 can only provide a momentary pulse output (for solinoid point motors). A lot will depend on the make of semaphore signal. If its one of the latest Dapol types then no you can't. If its a very old Hornby Dublo type which used a solinoid then yes. Link to comment Share on other sites More sharing options...
idlemarvel Posted September 9, 2014 Share Posted September 9, 2014 You can use pulse output to drive the "new" Dapol semaphore signals, but you need a relay or two in-between. I put an entry about this in another forum thread recently. Here is the document on Dropbox:https://www.dropbox.com/s/fd8sgf7hjh53ezz/Operating%20dapol%20Easi.fix%20Signal%20with%20DCC.pdf?dl=0It has two diagrams, one for signal only, one for signal and point off same decoder port. Link to comment Share on other sites More sharing options...
Jailor Posted September 9, 2014 Author Share Posted September 9, 2014 Thanks all, yep am going to buy Dapol as Hornby do not sell any will look at idelmarvel post but might be too complicated for me. Link to comment Share on other sites More sharing options...
Flashbang Posted September 10, 2014 Share Posted September 10, 2014 HiAs I stated in my reply you cannot operate a Dapol signal from a AD-S8 etc. If you try connecting the two yellow wires to the output of the decoder it wont work and possibly would destroy the latching mechanism of the signal. Hence my reply say it wont work a Dapol signal.Of course you can add 'extras' after the output like a relay or other means of logic switching, but that was not what was being asked! As the OP has now replied saying adding a relay is perhaps a step too far, this may also be the same for many other forum users too? Link to comment Share on other sites More sharing options...
Teedoubleudee Posted October 8, 2014 Share Posted October 8, 2014 There's a visdeo on youtube showing exactly how to do this using a cheap relay from Maplin. You can find the video under "Fitting signals controlled by DCC" by Simon's Shed (not me BTW) Link to comment Share on other sites More sharing options...
Teedoubleudee Posted October 8, 2014 Share Posted October 8, 2014 I can now confirm that this arrangement does indeed work as I've temporarily connected mine up this afternoon to a spare port on my ESU switchpilot. Link to comment Share on other sites More sharing options...
