Cronan Posted September 15, 2014 Share Posted September 15, 2014 I have installed the CD TrackMaster and activated it successfully but what is bugging me a bit is reading the PDF it says somthing about a trial version? So how do I know I got the full version or is it the full version cause I got the CD and activated it?It says 1.08 in the right hand corner.Also when I tried to install it first time it installed but when I went load it it came up with a error so I uninstalled it and reloaded and that worked so that shouldn't cause any problems ? I didn't activate it then but activated it when I reinstalled it.Thanks in advance. I think it's the full version but not too sure. Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted September 16, 2014 Share Posted September 16, 2014 When installed afresh from the CD or downloaded and installed TrackMaster starts off as an evaluation version until you activate it with your Key, which you will find in your CD case.You can easily tell if it is activated or not as the word "EVALUATION" will no longer appear on track plans when activated. Also, you will be able to add more than 30 pieces of track (30 being the limit for evaluation versions). Link to comment Share on other sites More sharing options...
Cronan Posted September 16, 2014 Author Share Posted September 16, 2014 Thank you very much I've activated it so it's the full version. I must of missed or didn't notice it as I pretty much activated it straight away. Thank you Link to comment Share on other sites More sharing options...
