tom_dewar Posted September 19, 2014 Share Posted September 19, 2014 Hi I recently purchased a R1172 Majestic e-Link Train Set, installed the enclosed Railmaster CD, then followed instructions to update to version 1.56. When I then try to Activate the software I get a message saying that it will not activate and to check Internet connection and Activation Key. I have read and followed the instructions in the Railmaster Guide and set the program to 'Run as Administrator'. I have also set the exception for the program within the installed McAfee Security system ( which is set as over riding the Windows Firewall) as directed i.e. Access : FullNet Guard : Off Internet connection is fine and working O.K. The software will still not activate. Activation Key on C.D. packaging is RM249 - CHD8N - 5HA72 - 259LM - GNDE5 My PC Details are: Toshiba Lap TopProcessor : CPU 1.80 GHzRAM : 6.00GBSystem : 64 - BitWindows 8.1Security McAfee I would appreciate you assistance. Many Thanks Tom Link to comment Share on other sites More sharing options...
gilbo2 Posted September 19, 2014 Share Posted September 19, 2014 OPPS - remove your license key from the above thread straight away using the edit button !!!!!!!!!!!!!You only get 10 minutes though, after that Hornby can remove it for you.As you have done all the usual things, contact Hornby support through the "?" button. They will then fix it for you. Link to comment Share on other sites More sharing options...
St1ngr4y Posted September 19, 2014 Share Posted September 19, 2014 If he can't connect to the internet to activate, he may not be able to send a ? message either.If so, an email tosupport@rail-master.commay be worth a try.Ray Link to comment Share on other sites More sharing options...
Augustus Caesar Posted September 19, 2014 Share Posted September 19, 2014 @tom_dewerPlease refer to the thread "Internet" and read my advice re the McAfee program and others like it. You will probably find your solution in that. McAfee is almost certainly your problem here as it WILL block RM even though you may have added an exception to its firewall. That program is no good with RM so get rid... as said though refer back one level on this forum and read my posts there.Also... contact admin on here as dgilbert2 says to get rid of the key you added to your post! This is YOUR key and you don't want unscrupulous folk using it as it can only be used on ONE machine... Link to comment Share on other sites More sharing options...
