alan_french Posted September 22, 2014 Share Posted September 22, 2014 Does any boby know where I can get to see a schematic layout of a hornby select.As I have blown a few pence transistor. But blown. yes no numbers left on it. Do need to know the number to go buy 1 Thanks gang Link to comment Share on other sites More sharing options...
96RAF Posted September 22, 2014 Share Posted September 22, 2014 If you can see the circuit ref - i.e. Tn - then contact HCC and they may give you the transistor type and details, which you will need when trying to source one from say RS Components or Maplin.If it had been an Elite then as there are two of most things in there you could look at the other one to glean the details. Link to comment Share on other sites More sharing options...
Michael_A Posted September 22, 2014 Share Posted September 22, 2014 Maybe somebody will open theirs up and tell you.Question is, why did it fail so dramatically, and what else has been damaged? (The current réquired to blow a transistor has flowed elsewhere in the circuit) Link to comment Share on other sites More sharing options...
alan_french Posted September 22, 2014 Author Share Posted September 22, 2014 Hi yes i know what i did to blow it.My own fault so no worrys about that. Link to comment Share on other sites More sharing options...
96RAF Posted September 23, 2014 Share Posted September 23, 2014 'fess up Alan.What did you do......just so that no one else follows suit of course. Link to comment Share on other sites More sharing options...
