Captant Posted November 18, 2014 Share Posted November 18, 2014 Just tried to install the latest update 1.57. It didn't work. Froze the programme and the computer. Have contacted support. Had to restore the computer to earlier restore point. Am using windows 8.1. Suggest you make a new restore point before downloading the update; just in case. Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted November 19, 2014 Share Posted November 19, 2014 Several thousand users have automatically downloaded the latest update without issue. It is not necessary to create a restore point in Windows as the update in no way affects any Windows components. If your RailMaster did not work after the automatic update then the most logical explanation is that the file was corrupted during the download process, which is rare. In this case the simplest solution is to just download and install the update manually from www.powerpos.com/rail-master/rm_setup.exe and run it again. This will then correct any problems. Link to comment Share on other sites More sharing options...
jonworld.trains Posted November 19, 2014 Share Posted November 19, 2014 Got similar problem too, since 1.57 updatedddd Link to comment Share on other sites More sharing options...
jonworld.trains Posted November 19, 2014 Share Posted November 19, 2014 Would like RM Suport to open the posability that the updae 1.57 may be difficult for anyone who does not have a "normal PC' (RM Suport ) . What is a normal pc ?Got similar problem too, since 1.57 updatedddd Link to comment Share on other sites More sharing options...
RB51 Posted November 19, 2014 Share Posted November 19, 2014 Not sure what a normal PC is jonworld. Have you tried the Powerpos download route? R- Link to comment Share on other sites More sharing options...
