Smithy58 Posted December 6, 2014 Share Posted December 6, 2014 I haven't used railmaster for quite some time. NowI have come back to using it, it is saying I have the evalution software. When I put in the key it then tells me it is already registered. Then gives me the option to reset to which I say yes by clicking on the green tick. How do I know if it has been reset??? Link to comment Share on other sites More sharing options...
PJ_model_trains Posted December 6, 2014 Share Posted December 6, 2014 Hi SmithyFirstlyHave you opened RM with it connected to your eLink? or other controller?Has it automatically downloaded the latest update version 1.58?PJ Link to comment Share on other sites More sharing options...
RDS Posted December 6, 2014 Share Posted December 6, 2014 ... How do I know if it has been reset???I would suggest, if it works OK, then it has reset. If you still have the problem where it sugest it is the evaluation software, you would need to contact RailMaster support at Hornby.As PJ says, check you have the latest version of the software, there have been many many additional features added over the last few months. Link to comment Share on other sites More sharing options...
Southern1234 Posted December 11, 2014 Share Posted December 11, 2014 I haven't used railmaster for quite some time. NowI have come back to using it, it is saying I have the evalution software. When I put in the key it then tells me it is already registered. Then gives me the option to reset to which I say yes by clicking on the green tick. How do I know if it has been reset???I'm having exactly the same problem.I de-registered Railmaster around 9 months ago intending to move railmaster to a different PC, an idea I've since abandoned. I tried to re-register railmaster on the old PC and I get a message that it is already registered however it's still in an expired evaluation state and so I can't use railmaster.I have contacted Railmaster Support and they've replied with some suggestions but as yet I have no solution. Link to comment Share on other sites More sharing options...
Gitter Posted December 11, 2014 Share Posted December 11, 2014 Hi,when I started ( opened RM pro ) yesterday morning , it opened in evaluation and was demanding an RM Pro code / activation key. Closed and re-opened and it came on ok. Nearly had a heart attack. computers and I do not really hit it off , and I,ve certainly never had anything like that leap out at me 07:30 in the morning. Is it V1.58 ? Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 11, 2014 Share Posted December 11, 2014 Simply contact HRMS via email in the Help window of RM or at support@rail-master.com with your details and they will fix it for you. Link to comment Share on other sites More sharing options...
Southern1234 Posted December 12, 2014 Share Posted December 12, 2014 I haven't used railmaster for quite some time. NowI have come back to using it, it is saying I have the evalution software. When I put in the key it then tells me it is already registered. Then gives me the option to reset to which I say yes by clicking on the green tick. How do I know if it has been reset???I'm having exactly the same problem.I de-registered Railmaster around 9 months ago intending to move railmaster to a different PC, an idea I've since abandoned. I tried to re-register railmaster on the old PC and I get a message that it is already registered however it's still in an expired evaluation state and so I can't use railmaster.I have contacted Railmaster Support and they've replied with some suggestions but as yet I have no solution.Railmaster Suppport have now fixed whatever was wrong with my Railmaster setup.Many thanks chaps ! Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 12, 2014 Share Posted December 12, 2014 Well done Southern, and another example of the usual top flight service from them. Link to comment Share on other sites More sharing options...
