moorlander Posted December 11, 2014 Share Posted December 11, 2014 As a newbie i would like to ask if i need to fit DCC clips to the points in the current extension packs ? Link to comment Share on other sites More sharing options...
Zues Posted December 11, 2014 Share Posted December 11, 2014 Short answer, yes Link to comment Share on other sites More sharing options...
choralc Posted December 11, 2014 Share Posted December 11, 2014 I would add only necessary if your are running DCC fitted locos with a DCC Controller. Link to comment Share on other sites More sharing options...
moorlander Posted December 12, 2014 Author Share Posted December 12, 2014 yes - running dcc locos and controller - thanks Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 12, 2014 Share Posted December 12, 2014 And just to be doubly clear, the long answer is also yes. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted December 12, 2014 Share Posted December 12, 2014 Unless, of course, Moorlander is using a bus wiring system, in which case the answer is no, because each piece of track is already powered!There's nothing like throwing a spanner in, and confusing the system! :-) Link to comment Share on other sites More sharing options...
ModelerXYZ Posted December 13, 2014 Share Posted December 13, 2014 As long as you don't leave the spanner across the two tracks. If you are using DCC then yes you need the clips. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 13, 2014 Share Posted December 13, 2014 Sorry moorlander, my fault for leaving the opening for the spanner brigade! Refer to previous answer. Link to comment Share on other sites More sharing options...
moorlander Posted December 15, 2014 Author Share Posted December 15, 2014 yes - its completely DCC....Thanks for the responses.... :) Link to comment Share on other sites More sharing options...
