Peteboy Posted December 17, 2014 Share Posted December 17, 2014 Why does select controller cut out for about 2 seconds and then restart Link to comment Share on other sites More sharing options...
96RAF Posted December 17, 2014 Share Posted December 17, 2014 Overload usually. Does it do it when disconnected from the track. Link to comment Share on other sites More sharing options...
Peteboy Posted December 17, 2014 Author Share Posted December 17, 2014 Overload usually. Does it do it when disconnected from the track. Link to comment Share on other sites More sharing options...
Peteboy Posted December 17, 2014 Author Share Posted December 17, 2014 Overload usually. Does it do it when disconnected from the track. I think I have narrowed it down to mallard locomotive as two other locos run and it does not cut out but mallard on its own cuts it out. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted December 17, 2014 Share Posted December 17, 2014 Does this happen anywhere around the track, or just in one spot?Maybe a set of points?Look very closely at this spot, as the loco goes over it very slowly. Can you see anything with the wheels that might be causing it?It might be wheel back-to-back that is slightly out, or a whisker of wire you missed, that is touching somewhere as this particular loco goes over it. Link to comment Share on other sites More sharing options...
Peteboy Posted December 17, 2014 Author Share Posted December 17, 2014 Does this happen anywhere around the track, or just in one spot?Maybe a set of points?Look very closely at this spot, as the loco goes over it very slowly. Can you see anything with the wheels that might be causing it?It might be wheel back-to-back that is slightly out, or a whisker of wire you missed, that is touching somewhere as this particular loco goes over it. Link to comment Share on other sites More sharing options...
Peteboy Posted December 17, 2014 Author Share Posted December 17, 2014 Does this happen anywhere around the track, or just in one spot?Maybe a set of points?Look very closely at this spot, as the loco goes over it very slowly. Can you see anything with the wheels that might be causing it?It might be wheel back-to-back that is slightly out, or a whisker of wire you missed, that is touching somewhere as this particular loco goes over it.Thought I had narrowed it down to one of the locos but left 3 running for about 15 minutes with no problem but now they all stop together after about 1 minute,I am using the standard hornby transformer(1 amp),could this be the problem. Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 17, 2014 Share Posted December 17, 2014 No, not the transformer. Apart from anything, it should run 4 locos. At least modern locos are any older and converted to DCC? But try running 3 slowly then gradually increase speed. If they run on slow for a long period but you get a cutout when they go fast, it's a possibility, particularly if any are older. Link to comment Share on other sites More sharing options...
