Ms Dad Posted January 13, 2015 Share Posted January 13, 2015 I am new to all this, having bought a starter set, plus extra engine and a couple of track extension sets. (For my son, of course...) The original engine is programmed 03. The extra one was programmed 01. 03 is responding happily to all commands and running along both track loops, and into sidings. But 01 - although it worked for a week or so - is not responding at all: it will not even start. I admit I have probably pressed every button under the sun on the select controller - including in combination - in desperation. I have also restored factory settings on the controller, and tried reprogramming for 03.Could I have damaged 03 in some way?Any ideas? Thanks. Link to comment Share on other sites More sharing options...
poliss Posted January 13, 2015 Share Posted January 13, 2015 There are some things you could do, but if it's new then the best thing would be to take it back to the shop for repair or replacement. Link to comment Share on other sites More sharing options...
Ms Dad Posted January 13, 2015 Author Share Posted January 13, 2015 There are some things you could do, but if it's new then the best thing would be to take it back to the shop for repair or replacement.It's just I rather think it's something I must have done though. Because it has been working. Thank you for replying though. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 13, 2015 Share Posted January 13, 2015 I agree with poliss and think it most unlikely to be anything you have done. It will be a fault that has developed by itself. And it could be anything so best it goes back. Link to comment Share on other sites More sharing options...
poliss Posted January 13, 2015 Share Posted January 13, 2015 It could be that the decoder has become loose, or the decoder has lost it's programming, which can't be reset with the Select. It could be many things, which probably won't be anything to do with what you have done.if they were old locos I'd say swap the decoders over to see if the decoder has failed. Link to comment Share on other sites More sharing options...
