Adam. Posted March 2, 2015 Share Posted March 2, 2015 Hi, just recieved my class 24, have had in on the programming track but im not getting any response from the loco. I do have 2 other locos that are running fine. im new to DCC so keep it simple ;) Link to comment Share on other sites More sharing options...
96RAF Posted March 2, 2015 Share Posted March 2, 2015 If this loco is DCC Ready then it has a decoder socket but you need to fit a decoder before it will behave itself.If it is DCC Fitted then it will already have a decoder installed and should be behaving itself.If it is Hornby what is the R number and have you fitted a decoder. If not Hornby what is the make and model. Link to comment Share on other sites More sharing options...
Adam. Posted March 2, 2015 Author Share Posted March 2, 2015 Loco is DCC fitted however is a bachmann branchline Link to comment Share on other sites More sharing options...
96RAF Posted March 2, 2015 Share Posted March 2, 2015 Next question is what is your DCC controller. Link to comment Share on other sites More sharing options...
Adam. Posted March 2, 2015 Author Share Posted March 2, 2015 It's a hornby e-link Link to comment Share on other sites More sharing options...
Adam. Posted March 2, 2015 Author Share Posted March 2, 2015 Ive just changed the loco ID'S around a bit and managed to get it working, thanks for your help :) Link to comment Share on other sites More sharing options...
96RAF Posted March 2, 2015 Share Posted March 2, 2015 Ive just changed the loco ID'S around a bit and managed to get it working, thanks for your help :) We'll put this one down as solved then. Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 2, 2015 Share Posted March 2, 2015 Does changed the loco's ID round a bit just mean you changed it from 03, or did you figure out something really clever we should know about? As a pretty inflexible rule of DCC, locos run only on the ID set and all start on the default ID of 03. There has been some recent suggestion they can have different short and long IDs as these are set in different CVs but you have to change CV29 bit 5 (means you have to add 32 to use long IDs) to get from one to the other anyway, so can't have two at the same time. Link to comment Share on other sites More sharing options...
