Ajay1 Posted March 5, 2015 Share Posted March 5, 2015 I have just aquiried this beaut of an engine and although I'ts working fine soundwise, I am unable too work out how to utilize the full capabitlites of all the sounds that this model is supposed to produce. I understand once the engine is selected and showing on the Elite screen window pressing the function button repeatedly cycles through F00-F09 , F10-F19 ,F20-F28 , Off F .In the Instucton pamphlet that came with the model lists a complete function list F0 through to F25 , with F0 turning on the lights (which this model does not have functioning) F3 Horn Low-High works by selecting the first set of numbers F00-F09.My question is , How do you get the higher numbered functions to work?press the second set of functions and then key in say, 12 , 17 or what ?I would be greatful if anyone could hepl me understand the workings. Thanks Link to comment Share on other sites More sharing options...
96RAF Posted March 5, 2015 Share Posted March 5, 2015 You cycle through the screensSelect F0-F9 and press 0-9 to get those to work,then go to F10-19 and press 0-9 to get those to work,then go to F20-28 and press 0-5 to get those to work (F25 being as far as you can go).So to get F25 to work you cycle to that function set and press 5. To get F11 to work you call up F10-19 and press 1. Etc, etc.Note that some functions are toggled sounds - Using the Elite you switch them on, then you switch them off, but if you hold the function button pressed for a few seconds it acts like a momentary sound and stops when you release the button. Hope that helps. Link to comment Share on other sites More sharing options...
Ajay1 Posted March 5, 2015 Author Share Posted March 5, 2015 Ah!!!, I see . Thanks very much. Now that I understand a little more on how to select the incorperated sounds I'll get a lot more enjoyment from it.. Link to comment Share on other sites More sharing options...
96RAF Posted March 5, 2015 Share Posted March 5, 2015 Just to add AJ1 that the momentary sounds play through once pressed. You don't have to hold the button. Note also that you can only play one sound at a time. If you play the fan (toggled) for instance then the horn (momentary), after the horn has played through the fan will kick in again until it is switched off or another spot sound is selected. The background engine sound F1 plays all the time it is selected and alters automatically under control of the throttle and/or F5 Notch Up, F6 Notch down, F7 Return to Idle and F8 Thrash. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted March 5, 2015 Share Posted March 5, 2015 Ajay - are you using a Select or an Elite controller - or one of the computer gadgets like railmaster and e-link?If you have a Select, it is very limited on the access to the sounds and other functions.Also - there is another thread on here about the 37, so if you find and read that, it might answer the questions you haven't thought of yet! :-) Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 5, 2015 Share Posted March 5, 2015 2e0, he's said very clearly Elite and RAF has given him the correct Elite instructions for it? Link to comment Share on other sites More sharing options...
96RAF Posted March 5, 2015 Share Posted March 5, 2015 2e0, he's said very clearly Elite and RAF has given him the correct Elite instructions for it? Thanks Fishy - I was waiting for the penny to drop. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted March 5, 2015 Share Posted March 5, 2015 OOPS! Reminder to self - must read all the post carefully! :-( Link to comment Share on other sites More sharing options...
