MikeMJD Posted March 16, 2015 Share Posted March 16, 2015 Will the 1 amp elink power supply be ok to operate this decoder.or does it need more power?Mike. Link to comment Share on other sites More sharing options...
Chrissaf Posted March 16, 2015 Share Posted March 16, 2015 Mike, When I measured the current drawn by one of my R8247 decoders during a fault finding diagnostic exercise. I measured 14mA as the quiescent (idle) current. There will be a sudden surge of current when you fire a solenoid point to recharge the internal capacitors in the R8247. But this would still be quite low. I haven’t measured it in practice but I would estimate it to be about 150mA, 200mA at most. It is the R8247 internal capacitors that provide the high amperage current to fire the solenoid..I believe to the best of my recollection that their values are 4,700uF, but my memory might be failing as it was a long time ago when I took one apart to look inside..So in answer to your question: Yes OK to operate, No (more power not needed). Link to comment Share on other sites More sharing options...
Yelrow Posted March 16, 2015 Share Posted March 16, 2015 There is a long past post on this very point, where hornby confirm that they have big in house layout, with several points, all running on 1 amp. It is a tad confusing, as when i enquired about running my points, i was advised(not by Hornby) that i would need 4 amp transformer. So if its good enough for hornby, should be fine john Link to comment Share on other sites More sharing options...
MikeMJD Posted March 16, 2015 Author Share Posted March 16, 2015 There is a long past post on this very point, where hornby confirm that they have big in house layout, with several points, all running on 1 amp. It is a tad confusing, as when i enquired about running my points, i was advised(not by Hornby) that i would need 4 amp transformer. So if its good enough for hornby, should be fine john Many thanks. Link to comment Share on other sites More sharing options...
