GeoFF03 Posted June 12, 2015 Share Posted June 12, 2015 I’d like to see this kit reissued to the main range or even just added to the kitstarter list. The European strongpoint has been made available, though not with the vac-formed base of old, so why not this kit? Both the strongpoint and desert outpost are available in 1/32, a scale they are hardly suited for due to the unrealistic paper thin walls, and this would not be an issue in the smaller scale. Link to comment Share on other sites More sharing options...
nmcabecadas Posted June 12, 2015 Share Posted June 12, 2015 Very true, the build is much more suitable to smaller scales as these buildings have very thick walls, but I only buy them if the base is included. Adding the base boost the overall value and the building can provide a diorama base for itself. Link to comment Share on other sites More sharing options...
21fan Posted July 25, 2015 Share Posted July 25, 2015 If it's available in 1/32, why not in 1/76. Would be an excellent option for all. Link to comment Share on other sites More sharing options...
GeoFF03 Posted August 2, 2015 Author Share Posted August 2, 2015 I've missed out on two of these that showed up on ebay. The first, I was out bid in the last seconds and it went for over £30. Now I've just seen one go for for over £80! Come on Airfix, give us poor modellers a break and re-release this at a sensible price or add it to the kitstarter program Link to comment Share on other sites More sharing options...
nmcabecadas Posted August 2, 2015 Share Posted August 2, 2015 Amera sells a similar Desert Outpost with base and a vac form building. Link to comment Share on other sites More sharing options...
GeoFF03 Posted August 2, 2015 Author Share Posted August 2, 2015 Amera sells a similar Desert Outpost with base and a vac form building.I have one. The outer surface detail is soft and ill-defined. Thats why I'm still after the Airfix original. Link to comment Share on other sites More sharing options...
nmcabecadas Posted August 2, 2015 Share Posted August 2, 2015 Amera sells a similar Desert Outpost with base and a vac form building.I have one. The outer surface detail is soft and ill-defined. Thats why I'm still after the Airfix original.I scratchbuild most of my scenarios. The Desert Outpost can provide a starting point and as far as I remember, the walls from the Airfix original are very thin. Link to comment Share on other sites More sharing options...
