Russ1707821018 Posted July 10, 2015 Share Posted July 10, 2015 One annoyance with the current website is that it will switch from the UK to the US site when I don't want it to (I presume it detects that my IP address in the the US and assumes I want the US version of the site). This causes some problems. For example if I click on the airfix logo on the club portal page ( https://www.airfix.com/uk-en/memberships/club/portal ) I go to ( https://www.airfix.com/us-en/memberships/club/view ), which is blank. I can fix this manually, but then when I have the club page loaded and click on the link for the club exclusive kits the site directs me to this page ( https://www.airfix.com/us-en/shop/airfix-club-exclusive-kits.html ), which doesn't exist and gives a 404 error. The other links off the club page seem to work okay. Link to comment Share on other sites More sharing options...
Russ1707821018 Posted July 28, 2015 Author Share Posted July 28, 2015 Thought I might get an answer from admin in less than two weeks. Link to comment Share on other sites More sharing options...
nmcabecadas Posted July 28, 2015 Share Posted July 28, 2015 The uk-en or us-en should be set by a cookie, set from the option in the top, not by IP. If you test with TOR or using any IP masking software, maybe can get some clues. Blocking or losing cookies due to privacy level can also result in navigation problems. Link to comment Share on other sites More sharing options...
