DocDC Posted October 10, 2011 Share Posted October 10, 2011 I've set up Hornby Layout 7 (Oval with two crossover loops) but even with no engine on the track my Select controller simply continuously clicks alternating between two unreadable partial digital characters on the display and no train runs. All is fine when I disconnect BOTH the track limbs connecting the small oval on the right of the layout, which run more or less across the width of the layout.Any ideas? Link to comment Share on other sites More sharing options...
bocaj Posted October 10, 2011 Share Posted October 10, 2011 When The Select does this it usualy means you have a shor circit, Im not sure how to fix this as the only time it ocurs on my layout is when something derails and causes a break in the circit.Hope this helps,Jacob Link to comment Share on other sites More sharing options...
poliss Posted October 10, 2011 Share Posted October 10, 2011 I don't have the Hornby track plans book. Do you have a photobucket account you can upload the pics to? Sounds like the track layout has caused a short circuit. Are you using more than one power clip/track or feeds? Link to comment Share on other sites More sharing options...
DocDC Posted October 18, 2011 Author Share Posted October 18, 2011 bocaj said:When The Select does this it usualy means you have a shor circit, Im not sure how to fix this as the only time it ocurs on my layout is when something derails and causes a break in the circit.Hope this helps,JacobThanks. You were correct it was a short circuit. Turns out the circuit (one from the current Hornby layout book) has 2 reverse loops - customer help at Hornby were quick to reply and identify this and gave me advice on using an isolated section with a ReverseLoop Module (x2!). Link to comment Share on other sites More sharing options...
DocDC Posted October 18, 2011 Author Share Posted October 18, 2011 poliss said:I don't have the Hornby track plans book. Do you have a photobucket account you can upload the pics to? Sounds like the track layout has caused a short circuit. Are you using more than one power clip/track or feeds?Thanks. You were correct it was a short circuit. Turns out the circuit (one from the current Hornby layout book) has 2 reverse loops - customer help at Hornby were quick to reply and identify this and gave me advice on using an isolated section with a ReverseLoop Module (x2!). Link to comment Share on other sites More sharing options...
