knownothing Posted October 14, 2011 Share Posted October 14, 2011 I am sure that someone will tell me that I am being stupid but here is my problem. Using my Select everytime I change a point with a R044 lever I get a momentary short which makes the Select recycle as at startup. Using suggestions from other forume entries I pulled up my track and fitted Insulated Royal Joiners. Problem still there. Then wired in a brand new points motor and not connected in any other way to the track, still had the problem. Wired up the15v supply to my old Hornby 900 and all of the points work perfectly. Can someone please tell me what the H**L I am doing wrong or will I have to use an alternative 15v supply? Link to comment Share on other sites More sharing options...
poliss Posted October 14, 2011 Share Posted October 14, 2011 What power supply do you have for the Select? The 1amp or 4amp?I would use a seperate power supply for point motors anyway. Link to comment Share on other sites More sharing options...
Rog RJ Posted October 14, 2011 Share Posted October 14, 2011 The standard 1 Amp powers supply that comes with the Select is just not sufficiently powerful to operate point motors directly.As Poliss has suggested, use another power supply or include a CDU in the supply to the points or upgrade to the 4 Amp power supply or operate the points by using an accessory decoder Link to comment Share on other sites More sharing options...
knownothing Posted October 14, 2011 Author Share Posted October 14, 2011 Thanks guys. Looks like an upgrade is on the cards!! Link to comment Share on other sites More sharing options...
poliss Posted October 14, 2011 Share Posted October 14, 2011 Even with the 4 Amp supply it can still cause a brief interruption of power when point motors are switched. Link to comment Share on other sites More sharing options...
