Yug Posted September 30, 2015 Share Posted September 30, 2015 Why did the RAF change from green and brown to green and gray after the Battle of Britain ? Link to comment Share on other sites More sharing options...
Jonathan Mock Posted October 1, 2015 Share Posted October 1, 2015 It was felt that the Temperate Land Scheme (Dark Earth, Dark Green and Sky) wasn't suitable for changing combat operations so a new camouflage system - the Day Fighter Scheme - was introduced in August 1941 that consisted of (what would become) Dark Green, Ocean Grey and Medium Sea Grey, with a Sky fuselage band and yellow leading edges to the wings. Link to comment Share on other sites More sharing options...
Pretty Mediocre Modeller Posted October 1, 2015 Share Posted October 1, 2015 Although RAF Bomber Command did keep the Green and Dark Earth for the rest of the war, on most of its Main Force Aircraft. Link to comment Share on other sites More sharing options...
nmcabecadas Posted October 1, 2015 Share Posted October 1, 2015 Grey seems better than brown and Germans also have a grey/green pattern, but using a more geometric approach, with straight lines, while the British have more soft shapes. Modern aircrafts in Europe seems to use more grey, in different shades, than any other color. Link to comment Share on other sites More sharing options...
tim_vincent Posted October 1, 2015 Share Posted October 1, 2015 As I understand it, it was because prior to, and during, the Battle of Britain, the RAF's fighters would normally be either flying over the land, or dispersed on airfields when on the ground, when the green and brown camouflage would be most effective. After the Battle of Britain, the fighters ventured further afield and over the sea, where the brown would show up much more, and the grey and green were better camouflage. Link to comment Share on other sites More sharing options...
PhantomBigStu Posted October 2, 2015 Share Posted October 2, 2015 the changing role of the RAF - during the battles of France and Britan the role of the Fighter Command was defensive, the emphasie was camoflage when on the fields of France and Britain, where green and browns fit most. Once 1941 got going the role of the Fighter Command changed, no longer fighting off dailly bombing raids the main mission was offensive raids into France wither escorting bombers or so called cirus raids. Now the empahsive is camoflage in the air and over sea as well, green and grey is much more suitable for such Link to comment Share on other sites More sharing options...
Ratch Posted May 2, 2016 Share Posted May 2, 2016 Bump Link to comment Share on other sites More sharing options...
