cjb7 Posted January 16, 2017 Share Posted January 16, 2017 Hi this will probably be a Duh moment but I have just started on the new tool Blenheim and there are areas on the assembly instructions in orange which state do not glue together. If I don't glue (for example part A to B how is it going to hold together ? Page 1 and the leading edge stiffener is one example the initial under carriage frames another followed by the full undercarriage which also say's do not glue am I losimg the plot in this regard.Clive. Link to comment Share on other sites More sharing options...
Jonno65 Posted January 16, 2017 Share Posted January 16, 2017 /media/tinymce_upload/8d262d456da9fb677fea2a1a90010726.jpg hi CliveI do not think you are losing the plot. It is confusing in part to the new build airfix instructions.The orange areas in the assembly instructions are the "indicates final location"What is confusing is the "Do not cement" key is a Black Square. So all Keys should read from the left of the text starting with the black triangle for "Assembly Phase", White Circle for "Cement", Black Square for "do not cement" Red (Or Orange) square for "Indicates Final Location" and so on.I did the same as you - thinking the orange square was for do not cement - because I was reading the Key right of the text not left of the text as I should have been.I have included some diagrams to illustrate. (from the Hunting Percival instructions)I hope this is of some helpKind Regardsjohn Link to comment Share on other sites More sharing options...
cjb7 Posted January 16, 2017 Author Share Posted January 16, 2017 Thanks for that John I can now carry on building Regards Clive. Link to comment Share on other sites More sharing options...
Baggers1707822778 Posted February 4, 2022 Share Posted February 4, 2022 Hi sorry to jump into this old thread. But it the only one I found with a near answer to my question. In the instructions book the is the red square and some parts painted red. The instructions say "Indicates final location" what does that mean? I can not start the 1:24 Hawker Typhoon till I get the answer. :( Link to comment Share on other sites More sharing options...
Ratch Posted February 4, 2022 Share Posted February 4, 2022 In each stage of the instructions, the part highlighted in red was fixed at the previous stage and is shown in the correct position. Link to comment Share on other sites More sharing options...
