johnnydean1 Posted January 4, 2012 Share Posted January 4, 2012 I am sorry if I have posted this in the wrong thread.I got the Flying Scotsman train set for Christmas and was very disappointed when it didn't work properly.It will go backwards OK but it won't go forwards when the Tender is attached.The engine itself will go forwards but when it's attached to the Tender it stops almost immediatly.It's going back to Amazon on Friday unless I can sort it out.Any help would be appreciated.Thanks. Link to comment Share on other sites More sharing options...
Brightstar Posted January 5, 2012 Share Posted January 5, 2012 Hi jonnydean1,Are you sure it is a live steam Flying Scotsman, If not you should make a post in the general section of the forum.If it is a live steam version then the tender is not detachable as it contains the boiler for heating the water and I suggest you make a posting on the http://www.00livesteam.com forum where you can get advice on running problems. Link to comment Share on other sites More sharing options...
roberteuan Posted January 5, 2012 Share Posted January 5, 2012 Hi jonnydean1, Purchased Flying Scotsman train set for my son and have experienced similar problems when attaching tender, engine stops for no reason and controller cuts out all the time. Requested replacement from Amazon. Link to comment Share on other sites More sharing options...
trainlover23 Posted January 5, 2012 Share Posted January 5, 2012 Most definitely NOT a live steam version. It would appear that the two prongs on the loco to tender coupling are shorting out. GENTLEY make sure they are separated and it should cure the problem. ALso check that your track is laid correctly and that there are no obvious gaps or faults. I doubt it is a fault with the loco. Link to comment Share on other sites More sharing options...
roberteuan Posted January 5, 2012 Share Posted January 5, 2012 trainlover23 said:Most definitely NOT a live steam version. It would appear that the two prongs on the loco to tender coupling are shorting out. GENTLEY make sure they are separated and it should cure the problem. ALso check that your track is laid correctly and that there are no obvious gaps or faults. I doubt it is a fault with the loco. Link to comment Share on other sites More sharing options...
roberteuan Posted January 5, 2012 Share Posted January 5, 2012 roberteuan said:trainlover23 said:Most definitely NOT a live steam version. It would appear that the two prongs on the loco to tender coupling are shorting out. GENTLEY make sure they are separated and it should cure the problem. ALso check that your track is laid correctly and that there are no obvious gaps or faults. I doubt it is a fault with the loco. Link to comment Share on other sites More sharing options...
roberteuan Posted January 6, 2012 Share Posted January 6, 2012 On closer inspection of the engine there appears to be four prongs two of which make contactwith a tiny metal plate on the tender causing a short, which to me is a design fault as i would expect this set to work out the box with no intervention from me.How ever do i request a refund ? and whats the purpose of these prongs in this particular set ? Link to comment Share on other sites More sharing options...
trainlover23 Posted January 6, 2012 Share Posted January 6, 2012 roberteuan said:On closer inspection of the engine there appears to be four prongs two of which make contactwith a tiny metal plate on the tender causing a short, which to me is a design fault as i would expect this set to work out the box with no intervention from me.How ever do i request a refund ? and whats the purpose of these prongs in this particular set ?The majority if not all Hornbys steam tender locos have this feature and they are desinged to improve pick up. you have to be careful in handling them as they can easily be bent, it is all part and parcel of owning a model railway. If I were you I would cut them off. The ones UNDER the bar should never be tampered with. Link to comment Share on other sites More sharing options...
da4472vid Posted April 20, 2012 Share Posted April 20, 2012 what I tend to do is open the tender and disconect the top wire, as long as the loco wheels are cept clean, there there should be no ploblem. Link to comment Share on other sites More sharing options...
