I like cars Posted January 11, 2018 Share Posted January 11, 2018 A place to post any facts relating to track geometry that help you to make tracks work.For example:The straight on a crossover plus a half striaght = long straightAdjacent corners of crossovers are equivalent distances to 90 degree R2s, also meaning that two 90 degree R2s starting at a given point in a given direction and turning away from each other end alongside at the same points as a long straight. Link to comment Share on other sites More sharing options...
Twigman Posted January 12, 2018 Share Posted January 12, 2018 Cut a 22.5 R1 into 2 single lane pieces and a 78mm short straight into 2 single lane pieces.R1 inside right > S 1lane > R2 outside left covers the same length as a 1/2 straight - An easy way to separate the pitlane from the track in minimal space. Link to comment Share on other sites More sharing options...
Twigman Posted January 12, 2018 Share Posted January 12, 2018 Cut a 22.5 R1 into 2 single lane pieces and a 78mm short straight into 2 single lane pieces.22.5 R1 inside right > S 1lane > 22.5 R1 outside left covers the same length as a 1/2 straight - An easy way to separate the pitlane from the track in minimal space. CORRECTED i had an R2 instead of an R1 Link to comment Share on other sites More sharing options...
