GWR18 Posted July 17, 2018 Share Posted July 17, 2018 Hi all,Looking for spares to a live steam steam set I have recently bought. Does anyone know where I could find the power track and a spare cable that runs from the speed controller to the power track? failing this means buying the entire controller setup... which will be done as a last resort ......and (I know this is frequently asked) what distilled water is recommended... i can’t bring myself to spend £19 on Hornby distilled water off eBay! Any other tips or tricks before I get started are always appreciated! Link to comment Share on other sites More sharing options...
96RAF Posted July 18, 2018 Share Posted July 18, 2018 I believe the correct power track has screw down connectors to handle the extra high current needs of live steam, but I guess soldering suitably thick cable to the rails would suffice. Certainly no need to buy a new controller just to get the track and wire parts.Rob Link to comment Share on other sites More sharing options...
Go_West Posted July 18, 2018 Share Posted July 18, 2018 First try hornby for parts but failing that as Rob has said find some heavy cable and soldering is the best way to connect to the track so many poor runs can be tied down to bad connections you can buy all you need on eBay to connect the controller to the track the 5 pin plug the water the oil and cable have a look.ken Link to comment Share on other sites More sharing options...
GWR18 Posted July 18, 2018 Author Share Posted July 18, 2018 Thanks chaps for the good ideas. Hornby sadly doesn’t have any of the spare parts required so I’ve gone down the route of making my own cable! Look forward to getting it all up and running Link to comment Share on other sites More sharing options...
dave_armitage Posted September 14, 2018 Share Posted September 14, 2018 hi it looks like a few people are looking for live steam parts try the 00 live steam group google it, and you should be able eto buy some distilled water from local chemist for a couple of quid ebay a big rip off sometimes just thought i could helpcheers Dave A Link to comment Share on other sites More sharing options...
olly Posted September 16, 2018 Share Posted September 16, 2018 I think the 00 live steam club sell the spare parts and the correct water. you cant use normal distilled water as it would damage the locomotive think its to do with the purity take a look at there website https://www.oolivesteam.com Link to comment Share on other sites More sharing options...
Go_West Posted September 18, 2018 Share Posted September 18, 2018 Olly85sorry to say you are wrong if it is deionised water it will over time eat away the solder in the engine so should no be used, i would say any distilled water should be fine. I make my own distilled water which I have used for over 8 years with no problems and must have saved me £1000 most part water oil leads and plugs are on eBay if you take the time to look.ken Link to comment Share on other sites More sharing options...
Clickernick Posted November 10, 2018 Share Posted November 10, 2018 Ok,Sirstly as Go west pointed out, you are better to avoid the power track as it will melt due to the amperage of the system. Hornby faux pas number 1!if you have a permanent set up, solder droppers to all track sections, (easier with flexible track) and link all droppers to a ‘bus’ system to bring power to the layout. This is the best and only advice for trouble free power distribution for Hornby Live Steam!Secondly, as the OOLSC shop manager I can assure you of all your needs which are available from the online club shop. We are a very friendly bunch of miniature steam heads. The club is free to join, and as a member you will be able to obtain most of what you require to enjoy and maintain your loco/s. we shall be exhibiting at the Warley Show in 2 weeks time so if you can, please come along to acquaint yourself with us all.wew.oolivesteam.com Link to comment Share on other sites More sharing options...
