Jasek Posted December 12, 2018 Share Posted December 12, 2018 HiIve read you can have the headlights fully on by rerouting the power to the pickup? What im really after is the brake effect when you release the trigger? How is this acheived? I beleve ypu have to flash the chip does anyone know how to completer the process? I.e software, wiring etc? Is it done via plugging chip into a PC? Many thanks. Kind regardsJase Link to comment Share on other sites More sharing options...
Dr_C Posted December 12, 2018 Share Posted December 12, 2018 The recently upgraded C8515 (rev H) DPR decoder has four wiring points for lighting... in digital mode this gives... 1/ headlamps always on when car is on track.2/ tail lights always on which brighten as brake lights when brake button is pressed (or trigger released in systems with dynamic braking such as ARC PRO). Sounds like this is exactly what you are looking for. With older decoders such as C8515 rev F and rev G you are also correct in that you can reflash these decoders with in-car pro firmware to activate the brake lights. This thirdparty firmware is not supported by Hornby and reflashing is a oneway journey... once reglashed you cannot return to the standard ZHornby firmware. There are other benefits to reflashing... including for the rev H decoder... but that can be explored elsewhere... Hope this helps... C Link to comment Share on other sites More sharing options...
woodcote Posted December 12, 2018 Share Posted December 12, 2018 Hi Jase. Yes, you can get 'always-on' lights by connecting the light boards direct to pick-ups. If you have the newest version of the C8515 digital plug ('Rev H' with the grey packaging) then you can wire the lights to the chip and get working brake lights. There's a superb tutorial on Slot Forum here: https://www.slotforum.com/forums/index.php?showtopic=165874 Link to comment Share on other sites More sharing options...
Mikejs70 Posted October 7, 2021 Share Posted October 7, 2021 Will this be ok on analog track . I have cars that have been converted to lights always on but weary of trying them on analog track . Will they be ok ? Link to comment Share on other sites More sharing options...
Andy P. Posted October 10, 2021 Share Posted October 10, 2021 Please don't ask the same question multiple times.The lights will not stay on permanently in analog mode with this method.See my other responses and stick to one post for further answer please.Thanks Link to comment Share on other sites More sharing options...
Andy P. Posted October 11, 2021 Share Posted October 11, 2021 Addendum: I pulled up the old link posted above: The chip used is known for causing the cars in analog mode to be very hard to control. They will have no brakes and the acceleration will be nearly instant.As long as you don't hold the car down and give it full throttle though you can't damage them... Link to comment Share on other sites More sharing options...
