Arbuthnott Posted February 5, 2019 Share Posted February 5, 2019 Hello all, I have just bought 2 basic figure of 8 sets as they were on special offer & now have a double length track + some additional track bought separately. Both sets came with came with a P9400W, 1.2a adaptor. Sticking them all toghether I will end up with a track probably 3 times as long as original. Is 1 adaptor enough to power the full track? Should I connect both adaptors or will this cause a problem, or do I need a more powerful adaptor?Advice appreciatedThanks Link to comment Share on other sites More sharing options...
woodcote Posted February 6, 2019 Share Posted February 6, 2019 Hi Arbuthnott - welcome to the forum! You should be fine running standard Scalextric cars on that track length with the standard power supply. Good track and car maintenance should keep everything running nicely. In addition to the info in the set instructions, there are some good tips here: https://www.scalextric.com/uk-en/support/tips If you extend the track further or start using high-performance cars, you might look at upgrading the power supply, controllers etc - but that is for the future. I hope that helps. Link to comment Share on other sites More sharing options...
Andy P. Posted February 6, 2019 Share Posted February 6, 2019 Checking the tabs as menitoned in the page woodcote linked is a top tip and solves many many problems... Link to comment Share on other sites More sharing options...
Arbuthnott Posted February 6, 2019 Author Share Posted February 6, 2019 That's very helpful, thank you. Link to comment Share on other sites More sharing options...
