Garygas Posted March 25, 2019 Share Posted March 25, 2019 have two new scalextric sport ,trying to link the two tracks together approx 64 piece how do i go about this do i have to up grade the power if so to what can any one help regards Gary 😢 Link to comment Share on other sites More sharing options...
Andy P. Posted March 25, 2019 Share Posted March 25, 2019 Hi Gary and welcome,Your post is not entirely clear to me what you are asking.It sounds like you are aslking if it is possible to power 64 pieces of track on a layout?First and foremost the track must be in good condition and the connections tight:https://www.scalextric.com/uk-en/support/track-maintenanceSee the section about power breaks and drops.I will assume you are running analog (2 cars, 2 lanes) so the next question is what power supply.There are several on the market. If you are using the older sport powerbase you can use one that allows for 2 power packs to be plugged in to increse power.If you are using ARC ONE or ARC AIR https://www.scalextric.com/uk-en/shop/sets/app-race-control-arc.html you can modify the ARC ONE easily to work with the Sport powerbase. ARC AIR should provide enough power as is though I have heard of users using a 4 amp power supply.If that is what you are asking we can give you more tips if we know what system you are running.Thanks Link to comment Share on other sites More sharing options...
