Bogrotter Posted November 14, 2019 Share Posted November 14, 2019 I have just bought a used Subaru Police Car. It has a fault in that it needs a nudge to start it off & doesn't seem to run very fast + the controller gets hot. I'm suspecting the motor. I've stripped it to ensure it isn't being fouled by anything - just the usual fluff etc. As it's fitted with flashing lights + siren, does it use the standard motor or is there a difference?Thanks Link to comment Share on other sites More sharing options...
Andy P. Posted November 15, 2019 Share Posted November 15, 2019 Hi There,Is it this car?https://www.scalextric.com/servicesheets/index/download/id/285/If so it uses a standard motor in the sidewinder configuration.The motor may need a tiny drop of oil on the pinion shaft and your braids may need renewing.Also check for any obivous problems in the wiring.That should solve 90% of your "slow to start" problem. Link to comment Share on other sites More sharing options...
Bogrotter Posted November 15, 2019 Author Share Posted November 15, 2019 Many thanks for your advice,.Braids look ok (but will change them anyway) have checked & lubed the motor + although 1 wire from the braids was trapped under a screw, it's still passing power. When the car runs after a push, motor sounds ok & lights & siren both work.Will have a look on the site you suggest.Regards Link to comment Share on other sites More sharing options...
Bogrotter Posted November 16, 2019 Author Share Posted November 16, 2019 Fitted a new motor - runs like a goodun!! Link to comment Share on other sites More sharing options...
Andy P. Posted November 18, 2019 Share Posted November 18, 2019 Grand! Link to comment Share on other sites More sharing options...
