Idontwannaspendsolongonana Posted April 6, 2020 Share Posted April 6, 2020 I changed the braid plate of a car during an arc pro race and then the car became dead, tried changing back the old braid plate, a new braid plate and reconnecting the controller and the car still doesn't work, How am I supposed to fix this? Link to comment Share on other sites More sharing options...
Andy P. Posted April 7, 2020 Share Posted April 7, 2020 The plates have not only a top and bottom but also a front and back. Take a look at a car that work s and make sure the plate is the right way around in all directions.Also, it is rare but a pickup can slip off during the plate exchange.Make sure you see two metal contacts where the plate is placed.If you can see them and the palte is the right way(s) round get a 9 volt batery and apply power directly to the metal contacts. If the motor turns then there is soemthing wrong with the seating of the plate. "Fluffing" the braids might help.If the motor still doesn't turn then a wire has likely come loose in the car.Failing that, it could be a digital chip problem. Link to comment Share on other sites More sharing options...
