Nito Posted June 27, 2020 Share Posted June 27, 2020 Difficulty removing the body for major maintenance. Followed instructions removed front bogy but body would not lift off!! Link to comment Share on other sites More sharing options...
gowest Posted June 27, 2020 Share Posted June 27, 2020 Hi Nitoon the older A3 engines you need to remove the oil screw in the chimney which can help then with the body single fixing screw removed pull the chassis towards the front of the body and with a rigging of the chassis from side to side at the same time pull away from the body hopefully it will pop out.good luck ken Link to comment Share on other sites More sharing options...
