WheelieMatt Posted October 7, 2020 Share Posted October 7, 2020 I've just bought this set second hand I'm in a wheelchair and live in a one bedroom bungalow so I want to make a decent foldable track table. I've not got a clue what I'm doing, but I want it to look decent for its size.If anyone can help me with a dummy's guide it will be greatly appreciated. Already got one 6' foldable table. Track dimensions on the box 6ft3w 4ft3 LThanks for your helpMatt Link to comment Share on other sites More sharing options...
Andy P. Posted October 8, 2020 Share Posted October 8, 2020 Hi Matt,I recommend getting a track planer like Ultimate Racer and setting up your layout there.It will tell you the exat dimensions you would need.Good luck! Link to comment Share on other sites More sharing options...
WheelieMatt Posted October 9, 2020 Author Share Posted October 9, 2020 Hi Matt,I recommend getting a track planer like Ultimate Racer and setting up your layout there.It will tell you the exat dimensions you would need.Good luck!I've downloaded Ultimaste Racer Andy. I know my track is a sport track, but how do I know which track pieces I've got so that I can select the correct track pieces when building my track on Ultimate Racer? Also how easy wouldit be to put my track on plywood and tressle tables, so that I can lean the track against a wall and just fold the table?Thanks Link to comment Share on other sites More sharing options...
Andy P. Posted October 11, 2020 Share Posted October 11, 2020 I think Ultimate Racer does a good job of visualizing the pieces of track. Besides they are all labelled with the C number for the piece of track.Putting a track on a hinge on a wall is pretty common. You just have to find a way to keep the track from sliding around.You can use hook screws. If the tempertature is constant you can fix it to the wood as well. Link to comment Share on other sites More sharing options...
