martin_reeder Posted January 16, 2021 Share Posted January 16, 2021 I've just got myself a slot.it car with the slot.it SSD chip fitted. Lane changing is ok, but it doesn't seem to want to trigger the timing loop. Any ideas? Link to comment Share on other sites More sharing options...
Andy P. Posted January 17, 2021 Share Posted January 17, 2021 Please use the search function as there are a few things that can cause this.If you what you find doesn't help come back and let us know.Good luck! Link to comment Share on other sites More sharing options...
martin_reeder Posted January 17, 2021 Author Share Posted January 17, 2021 I did have a search but didn't come up with something exactly like this. I was however wondering if maybe the position of the LED on the car is too far behind the guide blade. Would that cause an issue? Link to comment Share on other sites More sharing options...
Andy P. Posted January 18, 2021 Share Posted January 18, 2021 The LED must not be more than 1 cm behind the guide. Otherwise it is not picked up.The LED also should only protrude about 1-2 mm under the body.(probably not a problem if the lane changing is working)Guide blades must by black.This might help too:https://slotracer.online/community/showthread.php?tid=181&page=3 Link to comment Share on other sites More sharing options...
