khobs38 Posted January 20, 2021 Share Posted January 20, 2021 Hi all ,I have just obtained some booster cables , scalexetric one's with red plates and 2 prongs .one cable for each slot but no fitting instructions , how do you fit them and do you need one end near the original power source Link to comment Share on other sites More sharing options...
Andy P. Posted February 26, 2021 Share Posted February 26, 2021 Hi There,There are lots of videos online about this. Even if the videos are for other brands the principle is the same.Essentially though the rails have to always be kept separate.Let's say we call one lane/slot RED and one lane/slot YELLOW.Each lane/slot has a PLUS and MINUS(Negative) side.So the ideal way to connect is to run a cable from the PLUS/RED rail near the power base to the PLUS/RED rail as far from the powerbase as possible.Do the same for the MINUS/RED, PLUS/YELLOW and MINUS/YELLOW.If anything short circuits there will be smoke and possible sparks so take your time, follow the lane/slot around and if you have a multimeter double check before applying power. Link to comment Share on other sites More sharing options...
Crzy_88 Posted May 23, 2021 Share Posted May 23, 2021 I have just dusted off the old track and obtained enough track to make something a bit more substantial but now have power drop at the far side. Did this solve your issue? I also am running two transformers one for each track to avoid the power drop from both running off the same supply. Link to comment Share on other sites More sharing options...
Andy P. Posted May 24, 2021 Share Posted May 24, 2021 Before doing any sort of extra cabling I would make sure the track is in as good of condition as possible.... Again the search here and elsewhere provides lots of tips! Link to comment Share on other sites More sharing options...
