AndyThomas Posted March 15, 2021 Share Posted March 15, 2021 Hi there. Does anyone know which chassis is underneath the James body? I.E. If I aqquired a good James Body which hornby chassis would fit it and which tender would I need? Many thanks Link to comment Share on other sites More sharing options...
96RAF Posted March 15, 2021 Share Posted March 15, 2021 Pull the service sheet. I do believe it is identified as James.There are two sheets, both tender drive, one ringfield motor type and the other a modern motor unit Link to comment Share on other sites More sharing options...
Going Spare Posted March 15, 2021 Share Posted March 15, 2021 The easy part of your question to answer is that James was paired with a Schools class motorised tender. The James loco chassis was a one-off and it may be worth noting that the China-made body was secured to the chassis by a vertical screw at the front (service sheet 282) whereas the Margate-made original used a side-fixing screw just below the boiler (for which a service sheet was never issued), Co-incidentally, Hornby also used the R852 product number for one version of the Ivatt 2-6-0 but the chassis were not the same (service sheet 85A). , . Link to comment Share on other sites More sharing options...
96RAF Posted March 15, 2021 Share Posted March 15, 2021 SS423 also shows the bottom fixing screw.This one is DCC Ready with a socket in the tender. Link to comment Share on other sites More sharing options...
AndyThomas Posted March 15, 2021 Author Share Posted March 15, 2021 @Going SpareMany thanks for that. My idea of doing a cheap James is obviously not going to work if it was made on a bespoke chassis. I thought that Hornby may have utilised another loco chassis for it. All the bestAndy Link to comment Share on other sites More sharing options...
The son of Triangman Posted November 11, 2021 Share Posted November 11, 2021 Another alternative is to use a chassis from a smoke fitted Tri-ang R 251S 3F tender loco. The Hornby James body mould started life as the famous Tri-ang "Midlander" 3F tender loco. Hornby modified the body and married it with a schools class ringfield motored tender to make James for the Thomas range. It is possible with some work and the use of a suitable 8ba tap and suitable drill bit, a few screws to make old Tri-ang chassis fit. A syncrosmoke fitted R.251 will provide a nice smoke effect for James. Link to comment Share on other sites More sharing options...
Going Spare Posted November 11, 2021 Share Posted November 11, 2021 A nice idea, but anyone contemplating using the Tri-ang 3F chassis should keep in mind that negotiating modern points may be problematic with its coarse wheels, the X04 motor and synchrosmoke unit would overwhelm a modern controller and some means would need to be found to secure the James tender body to the 3F tender chassis. Link to comment Share on other sites More sharing options...
