Slot Car-Union.com Posted May 16, 2021 Share Posted May 16, 2021 Hello,I want to create a 4 or 6 lanes circuit with several ARC AIR powerbases.Unfortunately I can't do it because the frequencies of the controllers are blocked.With the ARC PRO it is possible to play several powerbases in a single room thanks to switches under the powerbase.Unfortunately on the ARC AIR, I did not find these frequency configuration switches.How to have a 4 or 6 way circuit with several ARC AIR powerbases please?CordiallyDenys Link to comment Share on other sites More sharing options...
Andy P. Posted May 17, 2021 Share Posted May 17, 2021 I saw this post somewhere else and the response is the same:They were never design for multi-lane use.You have to use powerbases with switches (newer ARC AIR and ARC PRO) and you will never get "one" race but each powerbase will run its own race and you will have to add the scores later. Link to comment Share on other sites More sharing options...
