LowRider32 Posted August 20, 2021 Share Posted August 20, 2021 Hi can you recommend an alternative power base replacement for my ARC Pro base with continental plug as this seems sold out in central Europe (local store and online) and the only ones I could find where with UK version only. Thank you Link to comment Share on other sites More sharing options...
Andy P. Posted August 23, 2021 Share Posted August 23, 2021 I have been using the UK version with a plug adapter for Europe for years...The power is the same, just the plug is physically different..It should not cost more than 5-8€.... Link to comment Share on other sites More sharing options...
LowRider32 Posted August 23, 2021 Author Share Posted August 23, 2021 Thanks, Andy! If it´s just the plug your suggestion would be the perfect solution! Will try that. Link to comment Share on other sites More sharing options...
Andy P. Posted August 24, 2021 Share Posted August 24, 2021 thumbsup Link to comment Share on other sites More sharing options...
