rman Posted August 23, 2021 Share Posted August 23, 2021 Hi 2 years ago I bought a Hornby Henry. Henry is loco driven and recently I have noticed that his tender has been causing it some problems. Sometimes he can pull trains and sometimes he can’t. I made pull 6 mk1 coaches one day and he struggling to pull them in one direction but he no problems pulling the other direction. I made him pull some wagons he no problems with them. Recently I made him pull 4 4 wheel coaches sometimes he couldn’t pull them and sometimes he couldn’t. So what’s is that whenever he pulls something he stops in one place but he’s wheels are moving but he’s not moving. Also he’s sometimes stops and start. One day I decided to make Henry run without his tender and noticed that Henry no problems without the tender. It’s only he runs with the tender that problems arise. Link to comment Share on other sites More sharing options...
Going Spare Posted August 23, 2021 Share Posted August 23, 2021 Although the motor is on the loco chassis, there are pick-ups on the tender wheels so the loco is fitted with an electrical drawbar. Check that:-a) loco - the jaw contacts below the drawbar are tightly gripping the pin at the front of the tender chassis and that the finger contacts above the drawbar are making good contact with the plate surrounding the tender pin without touching that pin. Adjust if necessary.b) tender - the wheels rotate freely. If they don't, check the positioning of the finger contacts on the backs of the leading and trailing wheels to ensure they are making good contact with the wheel rims and not getting caught in the spokes. Adjust if necessary. If the axle bearings are dry, a very small amount of model oil applied where the axles pass through the chassis block may also help. Link to comment Share on other sites More sharing options...
96RAF Posted August 23, 2021 Share Posted August 23, 2021 Service sheet 347 covers the loco drive Henry. The tender has a dummy ringfield motor housing installed and as GS says pickups that may have fouled up.https://support.hornby.com/hc/en-gb/articles/360016350479-HSS-347B-Henry-Railroad-Class-5Have a look at the service sheet to see how it comes apart for checking. Link to comment Share on other sites More sharing options...
TheAMRModelR Posted August 30, 2021 Share Posted August 30, 2021 i have the henry model and had similar issues. i found the metal rims of the tender wheels were detaching from the green spokes that are attached to the axles...! see if that's your issueMark Link to comment Share on other sites More sharing options...
