Adam-1224901 Posted October 30, 2021 Share Posted October 30, 2021 Hi. Im trying to get my quantum of solace set running. Ive set the track up and as soon as a car is put on the track its at full throttle. This also happens even if the controller track part is isolated. I also have another set. Speed challenge. Couple of vauxhall astras i think and swapped track controller parts over and still the same. Its driving me insane Link to comment Share on other sites More sharing options...
Andy P. Posted November 3, 2021 Share Posted November 3, 2021 Unless you have cross wired something there is likely a fault in the powerbase or the controller or both.Start by testing the powerbase only with the controllers in each port and swapping out power supplies.If one lane works fine but the other isn't then likely there is a cross wire in the powerbase.If it does it with one power supply and not the other the fault is in the power supply.. Link to comment Share on other sites More sharing options...
