Breandan-1227081 Posted November 15, 2021 Share Posted November 15, 2021 Hi there... I have become custodian of a Carrera Evolution 25312 set, which my kids have fallen in love with. Unf one of the cars has a broken wire connector to the brush unit. I can't see any advice/links on how replace these as they seen to be an older type, can anyone advise or point me at some guidance? Thanks in advance!I have put some photos on this link as well as those uploaded. https://drive.google.com/drive/folders/1R4UuiwdTfpi5z08yQ0iDebLvZ89ITepy?usp=sharing Link to comment Share on other sites More sharing options...
Andy P. Posted November 16, 2021 Share Posted November 16, 2021 Hi There and welcome,If you are talking about the red cable that is an easy fix.Strip 3-4 mm of the insulation off, take the brushes, insert the cable so you see the copper at the bottom and then insert the brush i.e. ensure there is contact with the wire and the brush.Good luck! Link to comment Share on other sites More sharing options...
Breandan-1227081 Posted November 16, 2021 Author Share Posted November 16, 2021 Hi There and welcome,If you are talking about the red cable that is an easy fix.Strip 3-4 mm of the insulation off, take the brushes, insert the cable so you see the copper at the bottom and then insert the brush i.e. ensure there is contact with the wire and the brush.Good luck! Thank you and you found me on FB as well! Link to comment Share on other sites More sharing options...
Andy P. Posted November 16, 2021 Share Posted November 16, 2021 Maybe I did and maybe I didn't ;-) Link to comment Share on other sites More sharing options...
