adcheck Posted November 23, 2021 Share Posted November 23, 2021 Link to comment Share on other sites More sharing options...
Andy P. Posted November 24, 2021 Share Posted November 24, 2021 adcheck2 posts discussion starter Posted at 19:44:35 Tue 23 Nov 2021Hi... please can anyone help in advising the correct method for wiring in booster cables to a permanent layout... comprising...6 car power base... pit lane and pit game... various straight changers and one out to in curved changer... many thanks in advance. AdamLooking to learn and offer advice also... I have a layout and some modelling skillsLast Edited 19:44:35 Tue 23 Nov 2021 Link to comment Share on other sites More sharing options...
Andy P. Posted November 24, 2021 Share Posted November 24, 2021 I moved the text to here as it seems to have gotten disconnected from the pictures...Based on the size of your layout simply adding a second power supply should solve any issues.All digital layouts have problems when more than 3 cars run on them when they are of any length with only one power supply.If you still have trouble it is worth checking the connections;https://support.scalextric.com/hc/en-gb/articles/360016220179-Scalextric-Track-Maintenanceas jumper/booster cables won't help if the connections are poor. Link to comment Share on other sites More sharing options...
adcheck Posted November 24, 2021 Author Share Posted November 24, 2021 Hi thanks for your reply... it is actually hooked up to 2 power supplies... I'm gonna check all connections again maybe reseat the lugs underneath the track and get everything nice and tight again... thank you again. Adam...;) Link to comment Share on other sites More sharing options...
