Paulali Posted December 31, 2021 Share Posted December 31, 2021 If i get an Arc air set can i still race the cars withoutout using an app? Link to comment Share on other sites More sharing options...
Paulali Posted January 1, 2022 Author Share Posted January 1, 2022 Just bumping the topic, anybody that can help with my question? Link to comment Share on other sites More sharing options...
Andy P. Posted January 1, 2022 Share Posted January 1, 2022 Hi There,All ARC products can be used without the APP.The controllers revert back to standard settings so any things like maximum output, acceleration curve etc. will not work.Also any features like pitstops etc will not work.For just running around the track though they will form fine and with ARC AIR and PRO you can enjoy the wireless controllers... Link to comment Share on other sites More sharing options...
Paulali Posted January 1, 2022 Author Share Posted January 1, 2022 Brilliant, again thanks for taking the time to reply Link to comment Share on other sites More sharing options...
Andy P. Posted January 3, 2022 Share Posted January 3, 2022 Thanks for the thanks!I have been doing this since 2013 on a volunteer basis I and I can count on my two hands how often I have been thanked. :-) Link to comment Share on other sites More sharing options...
Paulali Posted January 10, 2022 Author Share Posted January 10, 2022 Having the arc air C1359 set i realise i think i have an eu plug for the transformer, i only realised this when i recently bought another set,which has the normal 3 pin plug, I have been using C1359 with a 2 pin shaver adaptor, the set is fine and have had no problem with it, however, longterm am i going to damage the cars using this transformer? Link to comment Share on other sites More sharing options...
Andy P. Posted January 11, 2022 Share Posted January 11, 2022 The only difference is how the ground/earth is managed.If you make sure to unplug the system when not in use you should be fine. Link to comment Share on other sites More sharing options...
Paulali Posted January 11, 2022 Author Share Posted January 11, 2022 Again thanks Andy,i did ring scalextric this morning and they also said it would be fine Link to comment Share on other sites More sharing options...
